Bolt on Acura ZDX manifold and TB on 8th gen Accord - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 8TH GENERATION HONDA ACCORD (2008-2012) > 8G HONDA ACCORD PERFORMANCE DISCUSSION
Old August 15th, 2013, 08:49 PM   #1
2008 Honda Accord V6 EX-L
Got my Parts in can't wait to install it. I will update thread as I go along.
Acura ZDX Intake Manifold, ZDX Throttle Body
Now time for some measurements :-)
Im not a pro with the calipers so its +/- a mm or so.
Size Comparison.
Front Diameter of ZDX TB
Rear Diameter of ZDX TB
Front Diameter of Stock V6 TB
Rear Diameter of Stock V6 TB
Random Pics
korrupt3dazn is offline   Reply With Quote Quick reply to this message
Old August 15th, 2013, 09:58 PM   #2
frumaroll
six6's Avatar
Keep us posted. How much was the throttle body and manifold?
Old August 16th, 2013, 08:03 AM   #3
Intake Manifolds
Left Side: ZDX Right Side: Stock
Bottom: ZDX Top: Stock
Left Side: Stock Right Side: ZDX
Stock Intake Manifold with TB off
ZDX Intake Manifold with TB off
Intake Manifold removed
Everything reinstalled
You will need to transfer the studs off old Intake Mani unless you bought new ones here is a picture of the double nut method on removing it.
You will also need to transfer these to studs
On the ZDX manifold there is a little hose connector. Not sure what its called. You will need to cover this thing up or you will get a nice hissing noise. I just use some fish tank tube and seal the other end off.
Old August 16th, 2013, 08:14 AM   #4
frumaroll
six6's Avatar
Did u do a before dyno? How is she runnin now?
Old August 16th, 2013, 08:36 AM   #5
I didn't do a dyno before. She is running pretty awesome. Really responsive.
Old August 16th, 2013, 09:08 AM   #6
frumaroll
six6's Avatar
Nice! U plan on dynoing? And doesn't feel any quicker?
12' 6-6 coupe- Catless
05 6-6 coupe- Cai,pcds,rv6 j pipe, 3 inch custom exhaust, form n function coilovers. -SOLD
Old August 16th, 2013, 08:11 PM   #7
Shadowchaser's Avatar
I don't get it ..did you cap it?
I have hose connected to this tube.Did you rum V6 6mt OR AUTO?
Shadowchaser is offline   Reply With Quote Quick reply to this message
Old August 16th, 2013, 08:22 PM   #8
I have a Auto. I dont have a tube to go there. I went to Adv. Auto and picked up "Rubber Vacuum caps". Fish tank hose was only temp solution til I got to the auto parts store. It was a PITA to remove it.
Old August 16th, 2013, 08:45 PM   #9
I would recommend it remove Oil Catch Can.This type of mode can't be installed on V6 Accord.First of all that not PCV connection.
The way you connect You may experience a decrease in performance
Also i would recommend it ,make some research what difference between MT and auto on ZDX Manifold.
Old August 16th, 2013, 09:03 PM   #10
Probably would explain why I haven't seen the oil catch can catch 1 drop of oil lol.
Old August 16th, 2013, 09:21 PM   #11
You connect hose on proximate location PCV valve on 2002 Accord.
PCV valve on 2008-2010 V6 Accord located on the front ,next to oil cap and its look like plastic plug.
We dont have output nipple for hose connection,like older accord.PCV Valve should be replaced every 60,000 miles
Old August 16th, 2013, 09:44 PM   #12
I would take precaution High air pressure inside intake manifold may leak and give Cell (check engine) make sure its secure.
Old August 16th, 2013, 10:02 PM   #13
did you change spark plugs?
you may need 12290-R40-A02 SPARK PLUG (SXU22HCR11S) (DENSO)
Old August 19th, 2013, 08:28 PM   #14
Thanks for all the info Shadowchaser. I haven't changed spark plugs are pcv yet. Car has a little over 60k miles on it.
Old September 22nd, 2013, 09:06 PM   #15
new to this forum but is this setup a complete swap? what year model and what all parts are need?
gasmask34 is offline   Reply With Quote Quick reply to this message
Old September 29th, 2013, 02:47 PM   #16
Hey quick question on your MOD. After you installed it all did you have to adjust your ECU because of the Intake manifold and TB where changed from a 3.5L to 3.7L ?
Doctor Death is offline   Reply With Quote Quick reply to this message
Old September 29th, 2013, 02:54 PM   #17
Nope Just unplug the battery and plug it back in. Then let the ECU relearn.
Old September 29th, 2013, 03:15 PM   #18
What year Acura ZDX was the Intake Manifold and TB from, and can you instead put on a MDX IM & TB ?
Old September 29th, 2013, 08:41 PM   #19
I believe it was from a 2012 ZDX...
Old October 12th, 2013, 03:27 PM   #20
spart plugs
The spark plugs 12290-R40-A02 (SXU22HCR11S) (DENSO)
you are talking about I couldn't find them. Auto zone and pep boys don't have them. where did you get them.
Also you are running a dual nitrous system, and with the engine MOD you have done don't you have to get some special nitrous spark plugs because of the igniting pressure when you hit the nitrous?
please let me know. thanx
Old October 12th, 2013, 07:29 PM   #21
Banned
Will this fit the j30 and will be this a good performance mod for the j30 if this im and tb of the zdx fit?
lokyboy69 is offline   Reply With Quote Quick reply to this message
Old October 29th, 2013, 09:21 PM   #22
Any part numbers on the zdx man and tb? Also where did you get the parts?
Is your intake a 4" from Nvrdwn?
Thanks
GPMAX is offline   Reply With Quote Quick reply to this message
Old November 8th, 2013, 11:25 PM   #23
Engine Mod
I have a couple questions to ask. I hope you can help me.
1. Have you had any problems with your car regarding the Modifications you have done. I've gone the same rout as you have and installed it all with the Zex 82021 EFI wet universal nitrous system, dual purge kit, bottle heater, blow down kit, digital level gauge.
2. I have purchased a Intake manifold and TB from a 2012 Acura TL 3.7L (SHAWD) from Acura dealer, with both IM & TB spacers from throwdown performance, ported and polished the TB & IM to fit the spacers and gaskets and changed the spark plugs from the OEM to denso 1 step down colder plugs. I also relocated the Mass air flow sensor and Breathing hole from its original place to right before the bend on the Intake pipe due to the location for the nitrous port it needs to be at least 6 inches away from the TB.
Now I'm done with the IM & TB & re-wedding the Mass air flow and breathing hole on the Air intake pipe.
I started the car up and it would not level out on the RPMs it kept on turning of even when I pushed on the gas pedal.
I want to know if you have experienced anything like this and hopefully you can help me to where I went wrong.
Thanks,
Old November 11th, 2013, 08:17 AM   #24
only time I had issue like that was when I forgot to hook a hose back up to the Intake manifold. Same problem you described RPM jump and car would die. Made a loud hissing noise though so i was able to find the leak.
Old November 11th, 2013, 11:16 AM   #25
i want to see some numbers from it. props to you dude
V6 EJ is offline   Reply With Quote Quick reply to this message
Old November 12th, 2013, 03:14 PM   #26
Thnx for the info, when i checked everything i saw that they did the welding on the intake they welded it the wrong way and the mass air sensor was backwards. I fixed.
I have another question what did u do to the IM cover from the 2012 acura TL that it has a butterfly inside of it and the actuator assy; bypass valve.
What do you do with the butterfly and the bypass vavle because I installed everything and I can hear hissing from the bypass valve. Should I take them both out?
Old November 12th, 2013, 04:23 PM   #27
Banned
Will the j35z2 IM fit the j30a4?
Old October 26th, 2014, 05:25 PM   #28
Did you get a chance to see if the ZDX manifold height was any different?
bodyman is offline   Reply With Quote Quick reply to this message
Old October 29th, 2014, 09:06 PM   #29
I suppose it might be a little bit taller but not very much. I have one from the TL-SHAWD. It's pretty much the same, just bigger.
mzilvar is offline   Reply With Quote Quick reply to this message
Old November 26th, 2017, 04:48 PM   #30
pics or it didn't happen
TorontoJ35 is offline   Reply With Quote Quick reply to this message
