V6 turbo charged - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 8TH GENERATION HONDA ACCORD (2008-2012) > 8G HONDA ACCORD PERFORMANCE DISCUSSION
Like Tree3Likes
Old February 26th, 2018, 02:10 PM   #31
VCM disablers add resistance to the ECT1 sensor located under the throttle body on the block. This just tells the ECU that the engine is not "warm" enough for VCM (167 F and up).
Bonus from this is your alternator will always run in high output mode (13.5V+) and never go into low output mode (~12.5V).
That sounds right, the front cylinder head has the rocker arm controls on the passenger side. Along with the leaky internal gasket that has no replacement, those solenoids most likely control VCM operation.
@Darcy I'm sure if you're going forced induction on the J35 you're going to be using a K-Tuner, so VCM won't even be an issue as there is a software disable for it.
WILLYum is offline   Reply With Quote Quick reply to this message
Old August 4th, 2019, 11:39 AM   #32
Arrnav's Avatar
Originally Posted by Darcy3428 View Post
In regards to the problem with the VCM and cutting down to 3cyl, what major problems will this cause once the turbo is actually on the car.. I mean it doesn't take much for the ECO to not be active even on a normal road, a slight blip of the throttle and its off, in saying this you aren't going to make any boost till you get on the throttle (therefore there is no chance of Eco being on while on boost??) So no problem with the vcm and wanting to spool a turbo on 3cyl..... Or am I thinking way wrong??????
Bump, looking for an answer to this as well.
Arrnav is offline   Reply With Quote Quick reply to this message
