LX 177 hp Vs EX 190 hp - Honda Accord Forum : V6 Performance Accord Forums
Old July 18th, 2008, 08:17 PM   #1
Does anyone know the difference between the two configurations?
It seems like its the same motor, but one has the higher HP...
Learning is offline   Reply With Quote Quick reply to this message
Old July 19th, 2008, 07:42 AM   #2
Senior Member
chaqui74's Avatar
LX MODEL / EX MODEL
Engine Type In-Line 4-Cylinder
Engine Block/Cylinder Head Aluminum-Alloy
Displacement (cc) 2354
Horsepower @ rpm 177 @ 6500 / 190 @ 7000
Torque (lb.-ft. @ rpm) 161 @ 4300 162 @ 4400
Bore and Stroke (mm) 87 x 99
Compression Ratio 10.5 : 1
Redline 6800 / 7100
Valve Train 16-Valve DOHC i-VTEC®
Multi-Point Fuel Injection Standard
Drive-by-Wire™ Throttle System Standard
Variable Cylinder Management™ (VCM®) N/A
Active Noise Cancellation™ (ANC) N/A / Standard
CARB Emissions Rating ULEV-2/PZEV*
Direct Ignition System with Immobilizer Standard
100K +/- Miles No Scheduled Tune-Ups† Standard
I can't find the diffrence on HP.
Old July 19th, 2008, 10:39 AM   #3
LaLaLaLa
stupidaznmunkey's Avatar
prob just the way it was tuned. no physical difference - or maybe theres a different manifold on it or maybe a different cam running each engine...who knows there are endless variations that can change the amount of HP an engine has - but i think its just the way it was tuned.
Old July 19th, 2008, 11:41 AM   #4
Hatin' on me hatin' on me
inspired1's Avatar
if you rev the LX model as high as the EX model you'll get the same power :3 J/K probably the tuning.
inspired1 is offline   Reply With Quote Quick reply to this message
Old July 29th, 2008, 04:24 AM   #5
J30A1 => J30A5 => K24Z3
TH23's Avatar
The EX version has a freer-flowing exhaust system and, as you guys said, different tuning and a higher redline.
On a side note, the EX's free-flowing exhaust system apparently drones at low rpm, which is why Honda equipped the EX and EX-L sedans and all coupes with ANC (Active Noise Cancellation).
Old August 28th, 2008, 02:24 PM   #6
You are right. Mine sounds very similar to the 2004 TSX my mom had at one time. It more tone than a stock SI too i think. I carries a tone similar to my 5th gen. Prelude.
A&Fbro28 is offline   Reply With Quote Quick reply to this message
Old August 28th, 2008, 02:50 PM   #7
And this is for the 2003 and up models?
FenixQns is offline   Reply With Quote Quick reply to this message
Old August 28th, 2008, 02:59 PM   #8
"Certified Hybrid Killer"
SteVTEC's Avatar
http://www.hondanews.com/categories/814/releases/4106
190 Horsepower 2.4-liter Inline 4-Cylinder Engine (EX, EX-L Sedan; All Coupes)
Overview
The 2.4-liter inline four-cylinder engine that powers the EX, EX-L Sedan and LX-S, EX and EX-L Coupe is closely related to the engine in the LX Sedan and LX-P Sedan. The 190-horsepower inline four-cylinder meets ULEV-2 in all states, and PZEV (AT only) emissions standards in select states. Like the 177-horsepower engine, the 190-horsepower engine's PZEV variant has single exhaust valve operation at low rpm, dual-probe electrode spark plugs and special PCM mapping.
The key feature that allows this engine to make an additional 13 horsepower and 1 lb-ft. of torque compared to the 177-horsepower four-cylinder engine is a special exhaust system with larger diameter tubing and a variable-valve silencer design that nets a 31% increase in flow relative to the previous generation Accord four-cylinder system. Despite its performance advantage, this engine delivers the same EPA-estimated 21/311 City/Highway fuel economy (Sedan AT) as its less powerful counterpart. Inside the interior of 190-horsepower Accord models, an Active Noise Control system (ANC) helps reduce certain undesirable sound frequencies for greater passenger comfort. (Please see the Interior tab for more information.)
Old August 28th, 2008, 03:30 PM   #9
I was going to say the same exact thing... beat me to the punch!
justeddie is offline   Reply With Quote Quick reply to this message
Old August 28th, 2008, 09:25 PM   #10
nice find stevtec
954accord is offline   Reply With Quote Quick reply to this message
Old August 28th, 2008, 10:24 PM   #11
Bri
Car Enthusiast
Bri's Avatar
Send a message via ICQ to Bri Send a message via AIM to Bri
so does this mean that upgrading the exhaust of the LX/LX-P would give an increase that will net to almost the same power as the EX?
Bri is offline   Reply With Quote Quick reply to this message
Old August 29th, 2008, 02:15 PM   #12
probably.
tuning and gear ratios still give it an advantage.
