what is this light? - Honda Accord Forum : V6 Performance Accord Forums
Old October 16th, 2008, 12:33 AM   #1
方法についてはあなたが私のお尻にキス
Henrys86's Avatar
what is this light?
this is off my buddy's 08 sedan i4, he got a flat tire and after he replaced it this light turned on, he's confused and the guy doesn't even remember where his owners manual is to figure it out!
sorry the picture is blurry but i'm sure you can tell, i am guessing its low air pressure but not sure..
Henrys86 is offline   Reply With Quote Quick reply to this message
Old October 16th, 2008, 12:45 AM   #2
4.0L
VietNinjaJ30A1's Avatar
tire pressure.
Old October 16th, 2008, 06:26 AM   #3
Schu's Avatar
Owners manual pwns U
Schu is offline   Reply With Quote Quick reply to this message
Old October 16th, 2008, 06:50 AM   #4
should be able to reset the battery and it'll go away
sig86 cm8 is offline   Reply With Quote Quick reply to this message
Old October 16th, 2008, 09:02 AM   #5
its my Religion
hondaism's Avatar
low psi on i-vtec lobe #2
a big problem replace cams and he should be fine
hondaism is offline   Reply With Quote Quick reply to this message
Old October 16th, 2008, 10:00 AM   #6
xXxCLS bOoStEdXxX
slowaccord's Avatar
that can either mean air pressure is not correct or the sensor is messed up or not there. its probably just needing a reset after the flat.
Old October 16th, 2008, 11:15 AM   #7
4.0L
usually you shouldn't have to reset it...as your monitors are always monitoring the tire pressure. so when you get a flat fixed, it should be reading the new pressure when you turn your car on.
Old October 16th, 2008, 07:35 PM   #8
xXxCLS bOoStEdXxX
slowaccord's Avatar
i know in alot of american cars it won't reset alot of times on its own. So if it doesn't go away after about 10 miles of driving its best to manually reset it.
Old October 19th, 2008, 11:07 AM   #9
If it doesn't turn off after all four tires are inflated to the proper pressure, then call a Honda dealership as there is something wrong with your TPMS system.
fhqwhgads is offline   Reply With Quote Quick reply to this message
Old October 19th, 2008, 08:26 PM   #10
j35 psi 6sp
capnff's Avatar
haha nice
Old October 22nd, 2008, 01:15 PM   #11
Official V6P Retro Whore
dreamer's Avatar
Tp Ftw!
dreamer is offline   Reply With Quote Quick reply to this message
Old October 28th, 2008, 09:45 AM   #12
hmm
i used to get this aswell but as soon as you get the presure up alil you should be good just go to honda they will do fre in like 6 secs soo ya... i think it happens when air molocules in tires are steddy andthen when you start driving your tire expands and light flips off ... what was wrong in my situation it would flip on as soon as i started car then when i drove a bit it was gone soo ya
deep is offline   Reply With Quote Quick reply to this message
