2008 Accord V6 EX-L 262.3 WHP 235.9 TORQUE - Honda Accord Forum : V6 Performance Accord Forums
Old May 16th, 2009, 06:52 PM   #1
Thirdmanrunning's Avatar
These are the mods I have on this car.
AEM CAI
Greddy Cat Back Exauste
P2R Trottle Body Spacer
Un Orthodox Pully
I have the dyno graph saved on my computer does anyone know how to load them on.
Blue Devil
Thirdmanrunning is offline   Reply With Quote Quick reply to this message
Old May 17th, 2009, 12:49 AM   #2
onewheelup's Avatar
Just sign up and upload it to one of the free sites and post the link....
Photobucket or flickr are just a couple that will work.
Not bad numbers though...Id really like to see that dyno sheet
onewheelup is offline   Reply With Quote Quick reply to this message
Old May 17th, 2009, 12:55 AM   #3
frumaroll
six6's Avatar
what did u dyno stock?
Old May 17th, 2009, 12:55 AM   #4
frumaroll
six6's Avatar
and did the throttl body space provide any gains?
Old May 17th, 2009, 05:47 AM   #5
http://s674.photobucket.com/albums/v...s.jpg&newest=1
http://s674.photobucket.com/albums/v...h.jpg&newest=1
these should work just fine.
the spacer did it's job by keeping the intake manifold and the trottle body spacer a little colder.
Old May 18th, 2009, 06:50 AM   #6
L's TLS's Avatar
with sum pre cat deletes and a J pipe you should be able to get close to 290whp, good numbers. is this a 6spd and what pulley are you running? I also just saw this was on a Mustang. On a dynojet the numbers would be even higher so WOW Im impressed
L's TLS is offline   Reply With Quote Quick reply to this message
Old May 18th, 2009, 06:53 AM   #7
frumaroll
six6's Avatar
what was ur baseline dyno?
Old May 18th, 2009, 08:12 AM   #8
onewheelup's Avatar
http://www.v6performance.net/forums/...9&postcount=12
Old May 18th, 2009, 12:03 PM   #9
03 AV6 Coupe
hondav6's Avatar
great numbers. most stock 6MT dyno at 239WHP and 224WTQ. What great gains!
Old May 18th, 2009, 12:06 PM   #10
03 AV6 Coupe
hondav6's Avatar
now you dyno'd on a mustang dyno. Don't dynojets put out higher numbers(more accurate)?
Old May 18th, 2009, 08:32 PM   #11
dyno jets do give up higher numbers but the mustang dyno is at my shop. If i'm getting all my work done at Edic then why do somewhere else. The shop techs want to see that gains as much as I do.
Old May 19th, 2009, 07:04 AM   #12
L's TLS's Avatar
^^ thats the way to do it. If you start on one dyno dont change up and go to another to see what you gained. Those are awesome gains tho. Keep up the good work.
Old May 19th, 2009, 09:29 AM   #13
03 AV6 Coupe
hondav6's Avatar
heck I wouldn't go to a dynojet either if I had a mustang dyno at my shop! Good numbers! I would be curious to see how much more power you would put out on a dynojet though.
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old May 19th, 2009, 03:54 PM   #14
when i say my shop it's not really my shop but the shop I get all my work done at. Does anyone know of any more parts out there with horse power gains that fix my car and no stupid ****ing turbo jokes. Because we all know slapping on a turbo does nothing with out a tune to teach it what it needs to do.
Old May 19th, 2009, 03:59 PM   #15
03 AV6 Coupe
hondav6's Avatar
start with synthetic oil and premium fuel. Those are quick, cheap and easy yet small WHP and WTQ gains. Maybe soon richie will come out with a J-Pipe and Test Pipe for the 08-09 AV6 and that should give some impressive gains.
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old May 19th, 2009, 04:35 PM   #16
nOrcaL7thgen's Avatar
those are very good numbers
nOrcaL7thgen is offline   Reply With Quote Quick reply to this message
Old May 19th, 2009, 05:48 PM   #17
I've had nothing but 93 in my car it's whole life and I already have that oil. I was looking at lighter rims the enkies have some new ones that are around 17 pounds a piece which I think is really great.
Old May 19th, 2009, 07:36 PM   #18
Senior Member
chaqui74's Avatar
I probably miss it but what was your base number?
Old May 19th, 2009, 08:10 PM   #19
Those are some good numbers! I wish I could get around the same numbers on my A/T with similar modes, but I probably won't. You should track it and see what numbers you can run and give us feedback.
bobotee is offline   Reply With Quote Quick reply to this message
Old May 19th, 2009, 08:35 PM   #20
My fastest 1/4 mile time was 14.410 but this is still with original tires and When I get better tires I should have a better times because when I launch i ether spin the tires to much or bounce the **** out of the tires.
Hey chaqui74 I have the same H&R springs in my house There getting up on next pay check.
Old May 19th, 2009, 08:36 PM   #21
Hey chaqui how much those rims cost you and what do they weigh?
Blue Devil
Old May 20th, 2009, 04:58 AM   #22
Senior Member
chaqui74's Avatar
Not sure about the weight but i can tell you that there not lite weight . Heres a link
http://www.wheelsnext.com/wheels-tir...yperblack.html
Old May 20th, 2009, 09:55 AM   #23
Yeah man those don't look light at all. but they do look good. Does anyone know of a company that makes a high flow cat for the 08 accord I think that's the what I need I would like for some headers to come out so I can just not deal with the cats at all.
Old May 20th, 2009, 09:59 AM   #24
L's TLS's Avatar
^^^ Have you asked Richie if the J pipe and pre cat deletes he alreayd has will fit the 8th gen?
Old May 20th, 2009, 12:35 PM   #25
Yea i thought the 07-08 TL jpipe was super close, but they need an accord to test fit.
V-6 Nolo is offline   Reply With Quote Quick reply to this message
Old May 20th, 2009, 08:25 PM   #26
Who is richie? The tl j pipe is something I'll look into right now.
Old May 21st, 2009, 07:02 AM   #27
L's TLS's Avatar
When I buy my 8th gen next week Id be the guinea but I dont think Im close to any of the fabricators
Check otu the link below
http://www.v6performance.net/forums/...ad.php?t=99609
Old May 21st, 2009, 07:20 PM   #28
Well if you get any gains at all I'll be getting on that band wagon. Well guys I just had a ride in my buddy's brand new SS2 Camaro. Well.... that car is unreal. I hope I can stay with this car and I can find more and more power. Because if I get back from afghanistan and there isn't a way for me to improve everything I love about this car into something I can't live with out. Good bye beautiful blue and hello beautiful Camaro.
Old May 22nd, 2009, 05:53 AM   #29
L's TLS's Avatar
Yea a freind of mine just picked up his SS Camaro with RS package yesterday. Car is truly unreal, GM outdid themselves on this one. If I had that kindve MULAH to drop on one I wouldn't even be thinking about the Accord LOL,
Old May 23rd, 2009, 08:26 AM   #30
Who makes this J pipe?
