2008 6-6 Engine Issue - Honda Accord Forum : V6 Performance Accord Forums
Old October 29th, 2009, 11:39 AM   #1
Herp derp
civicdrivr's Avatar
My brother has a 2008 AV6 6MT with about 45k miles on it. For the past 10k miles or so he has been hearing alot of noise from the timing belt side of the motor. It sounds to me like the bearings in a pulley are shot.
He brought it to a dealer (he has the extended warranty) and they said they are going to replace a tensioner, shim it, grind down a tab on another pulley, and replace the timing belt at the same time. The dealer claims this is the reccomended TSB from Honda regarding it.
I searched online because this sounds to me like a half-assed fix. I couldnt find this TSB that they are talking about.
Does anyone here know of this TSB, or has anyone else had this noise?
Thanks.
civicdrivr is offline   Reply With Quote Quick reply to this message
Old October 29th, 2009, 12:01 PM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
how does that sound like a half ass fix?
Old October 29th, 2009, 03:01 PM   #3
03 AV6 Coupe
hondav6's Avatar
that sounds pretty legit to me and not like a half ass fix.
Old October 30th, 2009, 07:40 PM   #4
Schu's Avatar
its probably the steering pump bearing going bad
Schu is offline   Reply With Quote Quick reply to this message
Old October 30th, 2009, 08:15 PM   #5
-Brian
NexsoN's Avatar
wow, thats ALOT of mileage for an 08, i have a 2005 and have 47k
Old October 30th, 2009, 08:34 PM   #6
The End.
IcyAccord's Avatar
That's not alot..
06 honda civic having 200k at 2008, is A LOT.
http://www.8thcivic.com/forums/mecha...ng-strong.html
Currently as of September 1st, 2009, 400,000 miles.
http://www.8thcivic.com/forums/6509327-post679.html
Old October 30th, 2009, 08:45 PM   #7
-Brian
NexsoN's Avatar
Originally Posted by IcyAccord View Post
That's not alot..
yes it is alot, yours are just astro-nomical
Old October 30th, 2009, 11:06 PM   #8
Herp derp
civicdrivr's Avatar
Lol, both my brother and I put crazy mileage on our cars due to work. He got his car in late June of 08 with 3 miles on the odometer, I got mine Aug 8 2008 with 56,600 on it. I broke 100k last week.
The reason I thought it seems like a half assed fix is usually Honda revises the parts if they are causing a known issue, especially if said issue is 4 years old. I did find a TSB for the 05-07 V6s that described the same problem he had. He dropped the car off this morning and they replaced the timing belt, the tensioner, clearanced the engine mount bracket and shimmed the tensioner as per the TSB. They also adjusted the valves as they were a bit noisy.
The noise is no longer there, so he's happy, especially since it didnt cost a penny.
