PSI For 18" coupe wheels - Honda Accord Forum : V6 Performance Accord Forums
Old August 20th, 2010, 01:29 PM   #1
6mtsedan's Avatar
Whats the factory psi suggestion for the 18x8 coupe wheels with the 235s?
6mtsedan is offline   Reply With Quote Quick reply to this message
Old August 21st, 2010, 05:41 AM   #2
Senior Member
chaqui74's Avatar
you"ll be fine 32-35.
Old August 22nd, 2010, 12:42 AM   #3
Mark G.
jobata23's Avatar
Send a message via AIM to jobata23
^^ i set mine around the same psi
jobata23 is offline   Reply With Quote Quick reply to this message
Old September 5th, 2010, 03:17 PM   #4
40
jaxxx12 is offline   Reply With Quote Quick reply to this message
Old September 5th, 2010, 04:44 PM   #5
I set mine at 40 too. I haven't seen any odd wear on the tires at all. On this set or the old set.
Jumpingbean is offline   Reply With Quote Quick reply to this message
Old September 6th, 2010, 01:18 PM   #6
38 if your worried
Old September 6th, 2010, 08:38 PM   #7
09^CBP^6MT's Avatar
The factory setting on the door jam is 32 cold psi. They also metion in the manual to set it to 35 cold psi for "high speed driving" on page 337 and 338.
"We strongly recommend that you do
not drive faster than the posted
speed limits and conditions allow. If
you ever drive in a sanctioned
competitive event at sustained high
speeds (over 118 mph or 190 km/h),
be sure to adjust the cold tire
pressures as shown below. If you do
not, excessive heat can build up and
cause sudden tire failure."
09^CBP^6MT is offline   Reply With Quote Quick reply to this message
Old September 22nd, 2010, 11:24 PM   #8
Mike
Skidmarcx's Avatar
32 if you want traction... 35 for highway/long travel
Skidmarcx is offline   Reply With Quote Quick reply to this message
