08 6-6 Camshafts chewed up? - Honda Accord Forum : V6 Performance Accord Forums
Old April 9th, 2016, 03:20 PM   #1
Jaytronics's Avatar
I made this post over at Driveaccord. Anyone here familiar with such an event?
08 6-6 Cams chewed up? - Drive Accord Honda Forums
Sent from my SM-N910V using Tapatalk
Using Tapatalk
Jaytronics is offline   Reply With Quote Quick reply to this message
Old April 9th, 2016, 05:37 PM   #2
VCM motor?
Old April 10th, 2016, 05:09 AM   #3
M90SC Boosting 13PSI
NVA-AV6's Avatar
Timing jumped as you stated,piston to valve contact occured beating the roller on the lobe, I would be surprised if the roller for that lobe was not at least cracked.
Old April 10th, 2016, 06:01 AM   #4
Jaytronics's Avatar
Originally Posted by thisaznboi88 View Post
VCM motor?
No, this is the J35Z3. Manual transmission motor.
Here is the weird thing, this happened on both camshafts. Not just the side that was out of timing.
Th rear head is the one that slipped. The front head was in time still.
Using Tapatalk
Old May 20th, 2016, 12:08 PM   #5
I'm a Honda tech and have seen this before. It's more common on the K20 accords but also happens on the J30/32/35. The hardening of the metal wears down on the lobe
Ktm434 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2016, 12:53 PM   #6
Jaytronics's Avatar
I know when there was oil consumption issues, Honda would repair the motors in question. Any any way. The shop that just rebuilt my motor told me that they have seen this on another Honda. Or, on non roller type cams as well. And that was due to a lack of oil on the non roller ones. Pitting is something that just should not happen on our type of cams. Any way, if you have any advice on what I should say to Honda to see if they can help me out on the repair, I would be grateful. I would have liked to been able to have Honda repair my oil consumption issue. But, I have the 6-6. So, no VCM. Therefore no reimbursement or repair from them.
Using Tapatalk
Old May 21st, 2016, 03:29 AM   #7
Depends on your service history and where you purchased it. They are more likely to help a customer that either bought their car at that dealer or have serviced it there. But there's 2 ways of asking for help... One is having the dealer contact the Honda rep (which is when it's good to have a history with that dealer since they are vouching for you) or just contact them yourself. Honda has a "good will" warranty for good customers that are out of warranty. Sometimes it is a 50/50 split, sometimes they cover the part and you pay labor etc. it's definitely worth talking to Honda because most people that have a ligitimate complaint end up getting help. That's if you're having the work done at the dealer. Make sure you tell them you have always kept up with your oil changes and maintenance.
Old May 21st, 2016, 06:51 AM   #8
Jaytronics's Avatar
I am going to go with, no. I purchased the car with 108,000 on it two years ago. And from what the dealer told me, the previous owner did all the work them selves. So, there is no way to prove that they did their oil changes in a good time frame. Same goes for me. I have been doing all of my own oil changes and basic work. But, I just had a motor machine shop do the complete rebuild from the bottom to the top. But, thank you for your response. Completely appreciated.
Using Tapatalk
Old May 21st, 2016, 10:01 AM   #9
Yeah it's usually for cars that are barely out of warranty... Either over on miles but within time or over on time but within miles or just barely out. I had a bad catalytic converter on my car within time but was over on miles. They covered the part and I "paid" for labor but I'm a tech there so it was just a free part that I installed
Old March 9th, 2018, 12:29 PM   #10
im having a similar problem
typeRRRR is offline   Reply With Quote Quick reply to this message
Old March 9th, 2018, 12:33 PM   #11
most oil consumption in Hondas is PCV related
