2013 Honda Accord Coupe V6 6AT dyno - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 9TH GENERATION HONDA ACCORD (2013+)
Old November 25th, 2012, 11:18 AM   #1
03 AV6 Coupe
hondav6's Avatar
Stock 2013 Accord Coupe EX 6AT V6 dyno - 246whp and 224wtq. Very impressive and very underrated! I remember when TOV dyno tested ignition keys 8th gen accord v6 6MT. that put out 239whp stock. I wonder what a 2013 V6 6MT would put to the wheels! Thank you Bisimoto for the video!
Bisimoto Baseline of 2013 Honda Accord Coupe V6 EX-L - YouTube
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old November 26th, 2012, 10:19 AM   #2
Randomhero's Avatar
Holy cow nice!
Old November 27th, 2012, 09:37 AM   #3
Not too bad. I just test drove the 6MT that we have here and it has some serious balls to it!
AccordFlex is offline   Reply With Quote Quick reply to this message
Old November 27th, 2012, 09:42 AM   #4
Wow, I really want to drive the 6mt with full bolt-ons.
Old November 28th, 2012, 05:45 PM   #5
But how much does it weigh?
actACCORDingly is offline   Reply With Quote Quick reply to this message
Old November 29th, 2012, 09:03 PM   #6
05J30VTEC's Avatar
Nice!
05J30VTEC is offline   Reply With Quote Quick reply to this message
Old November 30th, 2012, 06:20 PM   #7
bka SouthBay7thGen
Drags2Riches's Avatar
don't you like that whine! it sounds like it has a supercharger
Drags2Riches is offline   Reply With Quote Quick reply to this message
Old December 3rd, 2012, 04:54 PM   #8
SweetV6's Avatar
i want more sound outa mine but not the ricey type sound any one got leads on a great sounding aftermarket setup
SweetV6 is offline   Reply With Quote Quick reply to this message
Old December 4th, 2012, 10:16 AM   #9
Sonnick's Avatar
Not bad at all. I'd assume the 6MT would put down 255-260/235-240 in that case. Damn.
Old January 21st, 2013, 07:47 PM   #10
My8thGen.com
godspeed's Avatar
I'm 1,500 Miles in now on my 2013 - I think it's time for a Baseline dyno and see where the numbers stand with mine.
I'll be honest, it is faster than my 8th Gen WITH all my mods. The 6AT is what the Accord needed from the beginning starting with the 8th Gen.
godspeed is offline   Reply With Quote Quick reply to this message
Old January 22nd, 2013, 08:13 AM   #11
6th and BEST Generation
tool462's Avatar
Send a message via AIM to tool462
Impressive, it might be time for me to take a trip to my local Honda dealer.
tool462 is offline   Reply With Quote Quick reply to this message
Old January 25th, 2013, 12:04 PM   #12
Sonnick's Avatar
Did you have the 6MT 8G or 5AT? If you had the 5AT, that explains it. The 6MTs should be pretty close. I believe the 9G isn't much heavier at all, if any, and only gained a few hp.
Instagram = j30_allmotor
Old January 25th, 2013, 04:18 PM   #13
frumaroll
six6's Avatar
I would like to see TOV do a dyno with the 9th gen 6mt. That will give us ground to compare it to the 8th gen numbers. Driving the 9th gen didn't feel any faster than my 8th at all
Old January 28th, 2013, 10:14 AM   #14
03 AV6 Coupe
hondav6's Avatar
I know TOV put down 239whp 221WTQ stock from an 8th gen accord 6MT. Since the 6AT accord put down 240WHP and 225WTQ, I am sure the 6MT will trump that. Even though it didn't feel any faster I am sure it will be as it has a better power to weight ratio then in the 8th gen.
In reality I think the engine is highly underrated. The TSX V6 that was tested put down 232WHP and 202WTQ (280 crank hp). At the crank the engine in the Accord 6AT is probably producing closer to 290hp and 265TQ!
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old January 28th, 2013, 10:18 AM   #15
frumaroll
six6's Avatar
What makes you think that the 9th gen auto trans is as power robbing as the 8th?
Old January 28th, 2013, 10:26 AM   #16
03 AV6 Coupe
hondav6's Avatar
The consistent power loss over the years with J series automatic transmissions. They seem to be robbing about 20-25% from the dyno numbers I have seen compared to crank numbers. Just my opinion. Even if the 9th gen transmission isn't as power robbing, I would doubt it is down to the Manual transmission power loss.
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old January 28th, 2013, 10:49 AM   #17
frumaroll
six6's Avatar
Yea I would doubt the manual trans will be power robbing as well. It would be strange to see 9th gen put down 10-15 more whp over the 8th gen considering the 9th gen is smaller weighs a little less but yet has same 1/4 mile times. Regardless I'm impressed with this auto dyno
12' 6-6 coupe- Catless
05 6-6 coupe- Cai,pcds,rv6 j pipe, 3 inch custom exhaust, form n function coilovers. -SOLD
Old January 31st, 2013, 06:33 AM   #18
I can't start new threads until I have 10 posts. Has anyone seen how GDI (gasoline direct injection) is affecting the engine oil in the new engines? TIA
Handa is offline   Reply With Quote Quick reply to this message
Old March 28th, 2013, 10:33 AM   #19
Niceeee.
Ethanol is offline   Reply With Quote Quick reply to this message
Old May 4th, 2013, 08:06 AM   #20
BLK98AV6's Avatar
Sounds very good. I too want to go and test drive the manual 6mt.
BLK98AV6 is offline   Reply With Quote Quick reply to this message
Old September 14th, 2014, 06:41 AM   #21
I wonder how an auto V6 would do on a dyno,as far as WHP? HB
Hot Brass is offline   Reply With Quote Quick reply to this message
Old August 23rd, 2015, 10:39 AM   #22
Great numbers.
ekim1 is offline   Reply With Quote Quick reply to this message
Old September 21st, 2015, 01:44 PM   #23
Hi All: When really flooring the accelerator in my 2014 V6 AT Coupe, how do you force the transmission to wind-out first gear towards redline? Even if I shift manually with the switches, the transmission will go quickly from first to second. Thanks!
-Paul
pifrankel is offline   Reply With Quote Quick reply to this message
Old January 19th, 2016, 03:41 AM   #24
Who is faster, j30a4 or 9gen accord coupe. Both with manual tran
sasa is offline   Reply With Quote Quick reply to this message
