Amplifiers - Honda Accord Forum : V6 Performance Accord Forums
Old January 14th, 2008, 06:54 PM   #1
Very Inspired
haiyter's Avatar
Send a message via AIM to haiyter
Amplifiers
Hello all, I never played with audio systems, nor do i want to have an expensive system that can annoy me with a loud bass etc. Anyways, i want to make my stock stereo louder. Would i just have to buy an amplifier to do this job?
haiyter is offline   Reply With Quote Quick reply to this message
Old January 17th, 2008, 03:31 PM   #2
Jr Member
jrvtecaccord's Avatar
You can start off by replacing all the factory speakers with aftermarket, I would just stick to "simple" coax design up front. You should be able to get decent speakers for the front & rear for around $100, and if you want to add an amp, a 4 channel amp to run those "simple" speakers should be around $120.
BTW, you would need a LOC(line out converter) if you plan to add an amp, unless you buy an amp with "high/speaker level" inputs, which I would suggest you look for.
PROPERLY installed, you should notice significantly better sound.
jrvtecaccord is offline   Reply With Quote Quick reply to this message
Old February 12th, 2008, 08:59 AM   #3
Work hard...play harder!
OCdjg's Avatar
Send a message via AIM to OCdjg
Or just buy a new headunit. You will hear the difference between your stock HU, and a decent aftermarket HU.
OCdjg is offline   Reply With Quote Quick reply to this message
Old February 12th, 2008, 03:44 PM   #4
josh52382's Avatar
First off if he would like to keep is climate controls then he should not change his head unit. If he really wants to change the headunit he could buy the install kit that would put the new unit in the storage bin but that is stupid. Second if you did get an amp depending on what brand you will not need a LOC. The kicker amps have a high level input that lets you wire into the factory speaker wires which is really easy. So the first move would to be change your speakers, however when you do this you will most likly lose a little bit of you mid range bass just to give you aheads up.
josh52382 is offline   Reply With Quote Quick reply to this message
Old February 15th, 2008, 10:34 PM   #5
7th Gen ACcord
xjdMb16a2six's Avatar
^^^ why is it stupid to have the headunit in the storage bin? i have mine setup like that and a lot of people that have sat in my car said it looks stock.
i agree. that was the first thing i got for my system and what a difference.
