installed headunit:mad: - Honda Accord Forum : V6 Performance Accord Forums
Old January 31st, 2008, 10:10 PM   #1
installed the radio. now my keyless entry doesnt work. well it works but doesnt unlock doors. and when i turn on the car the rpm and speedometer spring upward then goes back to normal. is there a spring on the hazard button? i have to push it in and pull out. and wheres a good ground for an amplifier? thanks
honda08 is offline   Reply With Quote Quick reply to this message
Old February 1st, 2008, 06:03 PM   #2
01accord is offline   Reply With Quote Quick reply to this message
Old February 5th, 2008, 03:15 AM   #3
Terence is offline   Reply With Quote Quick reply to this message
Old February 5th, 2008, 07:21 AM   #4
4.0L
VietNinjaJ30A1's Avatar
did you check all your fuses?
Old February 6th, 2008, 07:05 PM   #5
Blends No. 27
Vestax's Avatar
I get mad just reading the 1st thread because I can't understand it.
Year, make, model of vehicle?
Unless it's a 96-98 civic, there's no reason why you're HU install should affect your keyless entry.
Yes, there's a spring that sits between the housing and the actual front button on the Accords. The hazard can be easily broken upon removing if you're not careful. Take the hazard button out, and realign the spring.
The battery's ground is connected to your chassis. Your entire car's chassis is conductive. You can ground the amp anywhere on the car chassis as long as it has a low resistance (remove paint and do not use welded areas).
