help - Honda Accord Forum : V6 Performance Accord Forums
Old March 25th, 2008, 11:09 PM   #1
1bLwN_AcCoRd's Avatar
Send a message via AIM to 1bLwN_AcCoRd
help
need some help, so i just got a new sub for my car got a 12" arc flatine dual 4, and i'm getting a arc ks1000 amp next weekend. but for now i have it hooked up to a old amp i had lying around. its a audiobahn 4002T. the sub is wired for 8 ohms. this is until i get the new amp. well it was working fine for about 2 weeks and then it dies. the audiobahn amp is in protection mode. i figured its because its clipping, and it doesnt have enough power for the sub, so i kinda saw that one coming, but the other problem is now my components are not working either. I have alpine type-s components powered by a phoenix gold 2 channel amp. The amp isn't in protection mode, and its not even lighting up. What could be causing this?
1bLwN_AcCoRd is offline   Reply With Quote Quick reply to this message
Old March 26th, 2008, 09:24 AM   #2
Work hard...play harder!
OCdjg's Avatar
Send a message via AIM to OCdjg
You check the fuses, and cables?
OCdjg is offline   Reply With Quote Quick reply to this message
Old March 26th, 2008, 11:13 PM   #3
fuses are good and im gonna double check the wiring again, maybe its getting pinched somewhere or something..
Old April 20th, 2008, 12:27 PM   #4
make sure ground is connected properly too
psyduckiee is offline   Reply With Quote Quick reply to this message
Old May 14th, 2008, 05:52 PM   #5
Blends No. 27
Vestax's Avatar
You need to pull out a digital multimeter and set it to ohms. Read the resistance at the speaker inputs on the amps. While you're there, you can check for dc voltage too.
Old May 14th, 2008, 06:39 PM   #6
j35 psi 6sp
capnff's Avatar
check the rca's going to that amp, it could be a fried output on the head unit also..
Old May 15th, 2008, 12:08 AM   #7
found the problem, one of the wires behind the deck got separated. Thanks guys!
