How to troubleshoot sub/amp combo - Honda Accord Forum : V6 Performance Accord Forums
Old April 7th, 2008, 01:08 PM   #1
Chi
What me? Worry?
Chi's Avatar
HI Can someone point me in the right direction?
My Sub/amp combo was acting weird lately with it cutting in and out
After a while I wasn't able to get any power out of the amp so replaced it with a similar model.
After hooking everything up, the new amp is getting power, however when connected to the sub, there is no sound?
Anybody have any ideas on how I should begin troubleshooting?
Remote is good as well as the power going in
The fuse appears fine also as another amp also shares the same power connection.
Chi is offline   Reply With Quote Quick reply to this message
Old April 7th, 2008, 01:32 PM   #2
Formerly VTEC-v6!
N54TT's Avatar
Check your signals
Old April 7th, 2008, 01:38 PM   #3
Chi
What me? Worry?
Chi's Avatar
Can you advise on how to check for signals?
I'm trying to get a hold of a multimeter to verify voltage
I'm def getting power to the second amp and power from remote
I also switch out the power from my working amp to the sub amp and same thing
(no sound)
I'm wondering if I burnt out a VC on the Sub but not sure how to check.
Old April 7th, 2008, 01:46 PM   #4
Formerly VTEC-v6!
N54TT's Avatar
Check the signal cable from your headunit/LOC to the amp, and then check the cable from the amp to the sub(s).
By check, I mean make sure it's physically plugged in and not cut in half, frayed, melted, shorted, etc. You don't necessarily need a multimeter for that.
If you want to check the VC on the subs, hook up a multimeter and put it in impedance mode (Ohms), one pin to each terminal on the subs, compare the impedance to the specs for the speaker.
Old April 7th, 2008, 02:16 PM   #5
Chi
What me? Worry?
Chi's Avatar
Thanks VTEC, I'll see who I can finagle a multimeter from
Old April 20th, 2008, 12:22 PM   #6
For some reason, LOC always cause some sort of problem for us 7gens...
psyduckiee is offline   Reply With Quote Quick reply to this message
Old May 14th, 2008, 05:56 PM   #7
E85 and BOOST <3
accord14's Avatar
Send a message via AIM to accord14
this is a late response but maybe a bad ground or ohms are too low.
accord14 is offline   Reply With Quote Quick reply to this message
