Uninstalling Clifford autostart alarm - Honda Accord Forum : V6 Performance Accord Forums
Old May 1st, 2008, 10:35 PM   #1
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
So, I'm uninstalling the alarm in my car right now. Its an autostart made by clifford. I started to tak out wiring for the hood sensor and the siren. I then proceeded to taking out the interior wiring...
I got to the brain and un hooked all the wiring from it and removed it, and I also un removed another smaller module that was hooked up to the brain and another wiring harness...Thats where I stopped.
I went to start my car later in the night and it wouldnt turn over...so then I put the alarm brain back in, nothing. Next I put the smaller module back it, and it started up..
My question is how do I uninstall without messing up any wiring to start the car? I know there is another key under the dash that the alarm is wired to, and I dont know how to uninstall anything safely. Are there any more connections that im going to have to rewire?
Any help is much appreciated! Thanks in advance.
Old May 1st, 2008, 10:52 PM   #2
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
Ill be on this step with you too
But once I take everything off I think my car will start
But who knows ..
Old May 1st, 2008, 10:54 PM   #3
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
You have a autostart alarm? I think thats the only reason im having trouble, since the wiring is sliced into the ignition system.
Old May 1st, 2008, 11:02 PM   #4
THLA 2009 Bombsquad
Yeah I have a cheapo python alarm and remote start ..
Somehow I can never start my car with the key ignition so I had to use the remote start 100% of the time ..
I think it was with the wiring but Im going to have my sisters bf look at it for me since he's better at those kinda things
Old May 1st, 2008, 11:06 PM   #5
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
Well, I just got a flash light, so im going to go tear apart my dash and see if I cant get some progress done.
Old May 2nd, 2008, 02:51 AM   #6
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
nevermind...I think I got it all
Old May 3rd, 2008, 12:23 AM   #7
THLA 2009 Bombsquad
If you can do it then I can too =]
Old May 3rd, 2008, 12:29 AM   #8
Honda Fan
loginfailed's Avatar
So did you get it to start?
What about you, Dtownz Thrillah did you figure yours out yet?
In case you guys nee wiring info for your cars look here:
http://www.bulldogsecurity.com/
Here is the page with all the Honda wiring colors & locations:
http://64.85.6.121/diagrams/Diagramm...3&link=BULLDOG
loginfailed is offline   Reply With Quote Quick reply to this message
Old May 3rd, 2008, 03:47 AM   #9
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
wowm great site man! I'll bookmark just in case. I got everything uninstalled fine, just had a little re-wiring to do, but nothing challenging. Again, thanks for the info.
Old May 6th, 2008, 03:39 PM   #10
V6p OG
XxAznJoexX's Avatar
i think it won't start because you didn't connect the ignition wires together, that or the ground wire for the ignition
&mpt=[CACHEBUSTER]">
.:Nextstage Accord:.:Meguiars 2007-08:.:Nitto Tires:.:
XxAznJoexX is offline   Reply With Quote Quick reply to this message
Old May 6th, 2008, 05:34 PM   #11
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
yea, my ignition wire was sliced into. so i just had to reconnect it all.
Old May 6th, 2008, 06:10 PM   #12
V6p OG
XxAznJoexX's Avatar
rock on brotha!
Old May 14th, 2008, 05:50 PM   #13
Blends No. 27
Vestax's Avatar
Sorry I guess I didn't see this earlier.
The reason why you couldn't start your car is because your starter wire is interrupted and the installer severed it. This is a normal process for the starter kill relay. I think I posted this several times in the last 5 years.
Old May 14th, 2008, 11:54 PM   #14
THLA 2009 Bombsquad
So once I take out everything i will be able to start with my key?
Old May 15th, 2008, 02:15 AM   #15
Blends No. 27
Vestax's Avatar
As long as you reconnect the starter wire, and tape any exposed wires, you should be fine. If a remote start was installed, be sure to take out any transponder bypass or spare key if any.
