Help with DVD install with stock headunit - Honda Accord Forum : V6 Performance Accord Forums
Old May 12th, 2008, 06:31 PM   #1
T-Rob
ccordpower's Avatar
Send a message via AIM to ccordpower
I have a DVD player I want to put in the cubby. I have everything I need to mount it but I need help with the wiring. This is a '03 Accord btw. I'm wondering where to tap power from. And also, I don't want to replace the stock unit but I do want the sound from the DVD to player through stock unit (AUX) and speakers... Someone mentioned a high-low converter but I have no idea wtf that is. I have the audio attachment cable (for optional MP3 or CD Changer) and I was wondering if there was a way I could guess and check the wires to find the audio output...
ccordpower is offline   Reply With Quote Quick reply to this message
Old May 14th, 2008, 05:35 PM   #2
Blends No. 27
Vestax's Avatar
You should tap 12v behind the radio, and you want the unit to turn on and off with the car.
Whoever told you to get a LOC is an idiot. Line output converters are for turning your radio speaker lead outputs into low level RCA outputs. If you need sound to come from the DVD unit into your stock radio, you need an Auxilary input adaptor or wired FM mod.
Old May 16th, 2008, 10:26 AM   #3
re: Help with DVD install with stock headunit!!!
Nice thread! I really like your provided information. It's really helpful for me.
Thanks a lot!
jistik is offline   Reply With Quote Quick reply to this message
Old May 20th, 2008, 04:03 PM   #4
Duplicate Accounts
Send a message via AIM to sig86 cm8 Send a message via Yahoo to sig86 cm8
well if you are using that as your audio source why not just unplug the blue honda harness, extend it, and wire it to your pyle dvd player so the sound is directly through all speakers and you dont have to worry about messing with the stock radio
sig86 cm8 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2008, 11:56 PM   #5
Blends No. 27
Vestax's Avatar
Does the DVD player even have an internal amp to drive the speakers? Is it actually a source unit?
Old May 21st, 2008, 05:21 AM   #6
Re:Help with DVD install with stock headunit
Hi sorry I connot help you because I don't have any idea about ..
Good luck!
kelsey_4 is offline   Reply With Quote Quick reply to this message
