Stock radio replacement - Honda Accord Forum : V6 Performance Accord Forums
Old June 13th, 2008, 10:13 PM   #1
friends call me AcCoRd StUd
Send a message via AIM to ludestud
I have a 1995 odesssey that i drive to and from work and a truck i drive on the weekend. The radio went out, and i have been living with it for a year or so. I can't take it anymore....
WIll all honda ones plug right up to it? Say like a 2002 dual din cd player like i use to have in my accord.
ludestud is offline   Reply With Quote Quick reply to this message
Old June 13th, 2008, 10:43 PM   #2
J35A2K23B18CSRDETT2JZLOL
SIRSIG's Avatar
check how many pins the Odyssey harness has then go to http://www.installdr.com/InstallDocs/Honda/Accord.html check out the pdf files for installation
i had my 01 OEM 6disc put on my 00 CR-V, and it's a direct swap...
SIRSIG is offline   Reply With Quote Quick reply to this message
Old June 16th, 2008, 07:47 PM   #3
how hard would it be to do a newer model one in there? Just cut off the plugs and sorder the right wires back together using that site you posted?
Old June 16th, 2008, 11:32 PM   #4
Blends No. 27
Vestax's Avatar
Honda changed the harness somewhere after 1998. You should be fine with a radio before then but there weren't many double dins. If you get a male harness, match your 3 power/ground leads, and match the 8 speakers leads, you can pretty much use any radio.
Old June 17th, 2008, 07:49 PM   #5
where can i get the male lead you are talking about? I have installed aftermarket DVD players, and a few cd players.... Who would have thought that a factory radio was so hard
Old June 19th, 2008, 10:01 PM   #6
i have been searching on ebay and i found some that don't have the security code that you punch in to get the radio to play...
They say i have go to the dealer to get the code. What all is involved with that? No money involved is it?
