remote starts - Honda Accord Forum : V6 Performance Accord Forums
Old March 19th, 2007, 06:33 AM   #1
FAILLLLLLLL
whiteV6penguin's Avatar
Question remote starts
what are some pros and cons? thinking about getting one in a week or so... or just an alarm.. but think a remote start be pretty cool
whiteV6penguin is offline   Reply With Quote Quick reply to this message
Old March 19th, 2007, 02:57 PM   #2
XCLUSV
R-w00dickz's Avatar
Send a message via Yahoo to R-w00dickz
I just got a Viper 5900 2wks ago pretty cool
R-w00dickz is offline   Reply With Quote Quick reply to this message
Old March 19th, 2007, 03:46 PM   #3
DV8
Hella Functional
DV8's Avatar
MMMM... not really any Cons.....
Unless you're gonna be like me and get this key right here...
Then you can only start your car with the remote and not The key.
Old March 19th, 2007, 07:12 PM   #4
FAILLLLLLLL
i'm confused.... so if you have a remote start... you still have to use the key?? but if you get that instead... you just use the remote??? whaaaaat?
Old March 19th, 2007, 08:50 PM   #5
^_________^
stevent's Avatar
Send a message via AIM to stevent
The key needs to be in the ignition so that the remote start can be used. without it i dont think it would work.
stevent is offline   Reply With Quote Quick reply to this message
Old March 19th, 2007, 08:57 PM   #6
DV8
Hella Functional
DV8's Avatar
Python 990 Alarm with Remote Start..
1. Start the car with the remote
2. Let it warm up, then walk out to the car
3. Unlock car with remote
4. Put the key into the ignition, and turn to start position
5. Step on Brake to disengage remote start, engine stays on
6. Shift into gear and drive
Since i bought a key without a transponder chip, I can't start my car with the key. I'll have to start my car with a remote then use the key to drive it
If you step on the brakes without the key being in the ignition turned to the on position, the engine shuts off, and the alarm re-engages. This is a security measure, to ensure people don't get away with your car while it's warming up.
Old March 19th, 2007, 09:10 PM   #7
FAILLLLLLLL
ahhhhhhhh i seeeee i seeeeee now i get it... it makes sense this way, i've always thought you just drive when you start the car... loll
Old March 20th, 2007, 07:21 AM   #8
Banned
kleptodathief's Avatar
Send a message via MSN to kleptodathief
lol u still gotta put in the key once u remote start it! regarding this issue: u don't have to have the key with the chip inside to drive off once u remote start? i've always thought u had to have that master chip key...wudda been nice if the remote starter knew bout the key with the chip! so someone can still drive off when u remote start, is wat im basically trying to say
Old March 20th, 2007, 01:13 PM   #9
XCLUSV
R-w00dickz's Avatar
No, you have to have the original key w/ the chip inside to drive off. That is why you have 1 of your key put in one of that device (forgot what its called) that has a memory and hidden somewhere in your car. that device send signal to the brain if the key inserted has diff. code and only the same key code is the only one who can drive off the car. pro-thief probly has a way to get through all that lol.
someone correct me if im wrong or add more specific info.
Old March 20th, 2007, 01:15 PM   #10
datboiroy's Avatar
Send a message via AIM to datboiroy
next week when we meet up at the meet, ill give u a demonstration lol
datboiroy is offline   Reply With Quote Quick reply to this message
Old March 20th, 2007, 02:03 PM   #11
DV8
Hella Functional
DV8's Avatar
NO,
the chip is only used to START the car, and that's it. The transponder bypass is the one that contains the key, and the signal is used to start your car when you use the remote start. And that's ONLY used when you use the remote start button. But once your car is started, all you have to do is turn the ignition to the start, then you can get going, regardless of if you have a chipped key or not. So right now i'm using the red key that you see above to drive my car around, and i'm restricted to only starting my car with the remote. I keep the spare key inside my locked glove compartment in case my alarm ****s up.
Old March 20th, 2007, 04:58 PM   #12
Banned
re: alarm transponder bypass, i don't think mine uses an 'extra spare key' its just a module that mimics the chip? i have the viper791xv w/ remote start and i use my remote start atleast twice a day everyday! i do wanna get that red honda key!
Old March 20th, 2007, 05:29 PM   #13
DV8
Hella Functional
DV8's Avatar
There are two kinds of transponder bypasses, and thye both perform the same.
Old March 20th, 2007, 07:18 PM   #14
XCLUSV
R-w00dickz's Avatar
NO,
thanks for clearing that up
