Think I solved my own problem just need an extra opinion... - Honda Accord Forum : V6 Performance Accord Forums
Old March 28th, 2007, 02:35 AM   #1
Registered Driver
AccordboyV6's Avatar
Send a message via AIM to AccordboyV6 Send a message via MSN to AccordboyV6 Send a message via Yahoo to AccordboyV6 Send a message via Skype™ to AccordboyV6
Ok so I just installed an 4 way amp with a cap into my car. I got all excited and when I turned my car on everything started working... everything was playing so when I decided to see how loud it got.... everything cut out. Infact everytime it was about to hit the whole system just cuts out until I turn it back down again. So I tested the cap.. and moved the ground around.
After reading on 12volt and here I came up with the conclusion that the wiring job I did sucked and somewhere something is grounding...
What do you guys think ??
AccordboyV6 is offline   Reply With Quote Quick reply to this message
Old March 28th, 2007, 03:03 AM   #2
LaLaLaLa
stupidaznmunkey's Avatar
uhhh you might have a couple of problems
1) your amp is not putting out the right kind of ohms
2) the gauge of your wiring is too thin
3) your ground is too thin
4) you have a short
goodluck!
Old March 28th, 2007, 08:47 AM   #3
Formerly VTEC-v6!
N54TT's Avatar
Your amp is probably going into protection mode...you probably didn't wire the subs to the amp correctly
