Questions about alarm installation and Remote Start programming - Honda Accord Forum : V6 Performance Accord Forums
Old April 4th, 2007, 06:38 PM   #1
chromalusion00's Avatar
2 quick questions for those familiar with installation:
1)My Toyota has an old Clifford alarm (probably from the mid/late 90's) that has remote start. I just read the other post about the Python 990/Clifford 3.5 having built in turbo timer functions as well. Is it possible to reprogram an older alarm for this function? If so how?
2)If not- since the prior install already has tapped most of the wires I'm considering buying one of the above alarms, or maybe a CompuStar, and installing it myself. In addition to the turbo timer feature they have the 2way pager and other nice features. Since the prior install already has probably all/most of the wires I need tapped, I'm thinking it should make for a pretty straight forward install since I can just clip the old harness and then connect the appropriate wires to the new alarm harness? Is this correct or is there something I'm not thinking of that would make it a little more difficult?
Thanks for the help
chromalusion00 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2007, 05:31 PM   #2
Thanks for the help
1) No.
2) It is probably more difficult than you think. The older model Cliffords were pretty awesome in that they had all black wires and were only slightly labeled.
Although it is pretty straightforward for a competent installer since most all of the wires have already been tapped, it is probably going to be a big headache for you since you need to continually check diagrams and such to know which wire goes where.
I personally like to completely take out old systems before starting a new one.
egprelude is offline   Reply With Quote Quick reply to this message
Old April 5th, 2007, 05:55 PM   #3
Originally Posted by egprelude
1) No.
Thanks for the feedback appreciate it. I'm going to check out the existing install over the weekend to see how complex it looks.
Anyone have any opinions on the Compustar systems?
