system help!{noob} - Honda Accord Forum : V6 Performance Accord Forums
Old May 6th, 2007, 04:10 PM   #1
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
system help!{noob}
hey. i am newb at system so. bare with me... i am planning to get speakers for my car. i am also planning to get sub too but not right now... my main aim is to get one amp that can work with everything. from what i know and according to crutcfield and got some info..
questions:
1.speaker-6 by 9 for the rear and for the front which ones? 6.5 or 5.1/2?
2. amp- what channel am i looking for? cause i was plann to get a 4 channel and some one said wont work.. help???
.. have few more questions about lets start here. if any one can help woud be great!
Old May 6th, 2007, 04:11 PM   #2
metallikatz3's Avatar
Send a message via AIM to metallikatz3
get a 5 channel amp...it will run 4 speakers and a small sub
metallikatz3 is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 04:30 PM   #3
datboiroy's Avatar
Send a message via AIM to datboiroy
memphis belle MCH600 or MCH1300, boston GT-50, elemental designs nine.5, kicker zx700.5. those are some good 5 channel amps. just depends what speakers/sub you are putting and how much power they need. also your budget.
datboiroy is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 04:38 PM   #4
Giggity. Aw Right.
droopy's Avatar
+1 for roy. he knows what he's talking about. hahaha.
1. if you really really want, get rear speakers, but it's not completely necessary, as majority of your sound should come from your front stage, not rear stage. but then again, if you're getting are really getting a 5 channel amp, you might as well get rear channels. rather, get a 4 channel amp and bridge 2 for the sub.
also, 6x9 will drop fit in the back, but the 6.5's up front may need some cutting. if you are installing yourself and feel uncomfortable about cutting some sheet metal, i'd stick to the 5 1/2's. but 6.5 components will sound much better
goodluck!!
droopy is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 04:46 PM   #5
Champaned_out's Avatar
if you are getting subs in the future, dont bother upgrading 6x9's... put that money towards the sub
but a nice 2ch amp to power the fronts and a decicated mono amp to power the subs will be sufficent enough... and obviously a nice hu to pull everything together if you want the right sound
Old May 6th, 2007, 04:51 PM   #6
Bobby Lane Racing
nighthawk04v6's Avatar
alpine v12 ftw. simple clean, and good enough to power up all 4's and asub.
Old May 6th, 2007, 04:58 PM   #7
datboiroy's Avatar
id recommend getting 6.5" components for the front, a 12" or 15" sub sealed in a box custom built to the subs specs. a 2 or 4 (bridged to 2) channel amp for the front speakers. and a mono amp for the subs. id suggest something like.... boston pro60 comps, boston G5 12" sub, if you want, a 5 channel amp or 2 separate amps just incase you plan on changing your setup.
Old May 6th, 2007, 06:09 PM   #8
implayaz9's Avatar
ok so 6.5 speakers will fit front?.. i listen to a lot of trance/techno so i need very crispy sound.. i am thinking about going with:
front door- SPS17C2
rear -ALPINE SPS-69C3
sub- 12" or 10" kicker
.. let me know what you guys think.. and whats so good about going with component speakers thna just speakers?
Old May 6th, 2007, 06:17 PM   #9
-Brian
NexsoN's Avatar
6.5 will fit, but the door might need to be modded for the 7th gen in order to make room for the depth of the magnet, either you can cut the sheetmetal or what I recommand, building a baffle out of mdf, and build out the 6.5
Old May 6th, 2007, 08:36 PM   #10
datboiroy's Avatar
front door- SPS17C2
give me a budget and i can tell you a nice setup for trance/techno. i got friends who listen to that wit very nice sq setups.
Old May 6th, 2007, 09:12 PM   #11
7th Gen ACcord
xjdMb16a2six's Avatar
crisp and clean huh. get some focals.
Old May 6th, 2007, 10:15 PM   #12
V6p OG
XxAznJoexX's Avatar
roy is the master and king of audio down here in houston. he knows his stuff!!!
XxAznJoexX is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 10:27 PM   #13
ecko72's Avatar
yea man 6 1/2 will fit u will need speakers spacers and when the door is off behind that grill u got to cut that circle plastic that stick out of the door, so the speakers wont hit it. componets are good cuz they also lets u change ur tweeter and gives more power rating then the regular 6 1/2. and yea get a 5ch amp so u can power lows,mids,and highs.
ecko72 is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 11:04 PM   #14
implayaz9's Avatar
my buget is around 500-600. i know its not much but tryin to find the best for that much money.. this does not include sub price!..only speakers and amp
Old May 7th, 2007, 12:25 AM   #15
7th Gen ACcord
you can get some rainbows components for like 200 bucks and a 2 channel amp for like 100-200 bucks? try to look around for used deals.
Old May 7th, 2007, 07:34 AM   #16
datboiroy's Avatar
haha ya right, i wish. im still learning
get you some rainbow slc 265 components. pm 6spdcoupe, he can get you some. 12" JL W6 with hifonics amps. that will probably be a nice decent setup.
Old May 7th, 2007, 07:56 AM   #17
implayaz9's Avatar
whats so good about rainbow slc?.. do u think the alpine component are not as good or?..just wanna know.. why you choose rainbow(i have never heard of it).
..i already have a kicker 12" which i might use of i might invest in a 10"..dont wanna have too much base but wanna have at least a little feel of it with my music!..
.. u think 500-600 is less for setup? thought it would be enough for inner speakers(6 by 9 as well as the 6.5 setup) and an amp!(not including sub)
Old May 7th, 2007, 08:27 AM   #18
implayaz9's Avatar
let me explain my needs.. i wanna avoid getting a sub installed my car, so i am looking for the cleanest setup for inside the car that way i wont feel i am missing something. thats the main reason i was looking to get 6 by 9's at the back. as i have to use my trunk, SUB IS THE LAST THING I NEED!
datboiroy .. loda help kar ne!..
Old May 7th, 2007, 09:11 AM   #19
Bobby Lane Racing
for 500 bucks that's a piece of cake,
get a 4 channel amp, 6 1/2 in front and 6x9 in the back. with your budget, get infinity kappas, in front and back. amp deck and speakers will run you about 500.
Old May 7th, 2007, 09:36 AM   #20
datboiroy's Avatar
loda? sorri bro im an abcd haha.
Old May 7th, 2007, 01:02 PM   #21
7th Gen ACcord
hmmm.. i dont know if it would fit, but check out the eD eu700. they're 6.5in in subs. you can probably mount them in the 6x9 using a baffle. they will probably give out bass than some 6x9.
Old May 7th, 2007, 02:23 PM   #22
7th Gen ACcord
hey implayaz9, you go to csuf right?
Old May 7th, 2007, 10:50 PM   #23
implayaz9's Avatar
yup i go to csuf....why?
datboiroy.. my aim is implayaz9.. i am white washed too but know few things here and there..
Old May 7th, 2007, 11:52 PM   #24
Giggity. Aw Right.
droopy's Avatar
two eu700's probably isn't nearly enough for bass, but probably better than most 6x9's out there.
Old May 8th, 2007, 12:36 AM   #25
7th Gen ACcord
if you're on campus tues and thurs, you can hit me up to listen to my setup. bring a cd you like or familier with.
Old May 8th, 2007, 01:40 AM   #26
let me explain my needs.. SUB IS THE LAST THING I NEED!
so which is it... you getting a sub or not? if you dont care about spending $100 or so dollars on some 6x9s till you get some subs that will be fine... but if money is an issue just wait til you get a woofer in your trunk because upgrading your 6x9s and then getting a woofer is a waste of money
most people i know actually disconnect their 6x9s once they upgrade to subs because those rear fills wont even be noticable
Old May 8th, 2007, 07:36 AM   #27
implayaz9's Avatar
see my main aim is to get the best setup for the inside of the car. the reason why is that i really need to use my trunk and am tryin to avoid having a sub. so if my setup is lack of something down the line, i will end up getting one sub. so i rather try to get the best inside setup from now that way i have to avoid getting a sub down the line!
Old May 8th, 2007, 07:38 AM   #28
implayaz9's Avatar
i only have one class which is on tues nights... let me know ur schedule and may we can meet up.. if u ok with it!.. i work until 5.30 everyday so.. can meet after that!
Old May 8th, 2007, 11:40 PM   #29
7th Gen ACcord
oh i see. i have class on tues/thurs from 8:30am to 5:15pm.
Old May 8th, 2007, 11:49 PM   #30
implayaz9's Avatar
ohh ...i dont mind meetin on thurs but i get off work at 5:30 pm .. work in yorba linda.. let me know
