JL Cleansweep Install Question, 7th Gen Users - Honda Accord Forum : V6 Performance Accord Forums
Old May 10th, 2007, 09:11 AM   #1
-Brian
NexsoN's Avatar
Exclamation JL Cleansweep Install Question, 7th Gen Users
Hey Guys, I just ordered the JL Cleansweep 441dsp.
I am a bit confused for hooking it up, the main part I am confused about is connecting the 4 speakers outputs from the Cleansweep to the OEM Headunit. How exactly do I go about doing this? Do I need to tap into the OEM Harness? Do I just put the Honda aftermarket harness onto the stock harness and connect my wires like that, but then the stock harness would be disconnected from the STOCK HU , I am totaly confused on this part?
I am referring to page 7 the left hand side of this link
http://mobile.jlaudio.com/pdfs/11196.pdf
I know a few people on this forum have the CS installed and I need their help.
Basically, how do I connect the Cleansweep to my Stock HU
Old May 10th, 2007, 10:56 AM   #2
datboiroy's Avatar
Send a message via AIM to datboiroy
take the wires and splice into the oem harness and ur good to go
datboiroy is offline   Reply With Quote Quick reply to this message
Old May 10th, 2007, 12:26 PM   #3
-Brian
NexsoN's Avatar
And keep the harness plugged in?
I need someone who has already installed this in their 7th gen accord
Old May 10th, 2007, 12:44 PM   #4
I don't have the cleansweep, but I have the VHub Pro which required similar connections.
What I actually did was make a custom harness, so that I didn't have to cut and splice the stock connections. You keep the harness plugged in, you just cut the wires on the harness and the end that's coming from the radio, you connect to the input of the CleanSweep.
For my custom harness, I used a reverse wiring harness, and a normal one. But I did have to modify the connectors because Navi models use all 20 pins.
oh, and standard disclaimer applies. you take full responsibility..
alpha is offline   Reply With Quote Quick reply to this message
Old May 10th, 2007, 01:20 PM   #5
-Brian
NexsoN's Avatar
I am still totally confused? you say I dont have to cut the harness but then you said to cut the wires on the harness, I am sorry if I am missing something.
ah I need flytec in here!
Old May 10th, 2007, 02:10 PM   #6
datboiroy's Avatar
cant ask a local audio shop?
Old May 10th, 2007, 02:15 PM   #7
-Brian
NexsoN's Avatar
well, I asked a couple of guys and now I have an understanding on how to do it, basically I have to tap into the wires, but I will do it along the line so that it will not be as hard.
but my main concern is how will i connect my rca's, if the front/rear on the cleansweep go to the front rear on the 300/4, whats goes to the 500/1 for the subs?>
Old May 10th, 2007, 07:31 PM   #8
7th Gen ACcord
xjdMb16a2six's Avatar
you the a Y cable for the rear
Old May 10th, 2007, 09:28 PM   #9
I feel da need 4 6-speeds
flyvtec's Avatar
sorry dude, but i had a professional install my cleansweep because i didn't want to mess up my system. i can ask the installer on friday and find out how he did it.
Old May 10th, 2007, 09:55 PM   #10
-Brian
NexsoN's Avatar
flytec, i actually found out!
Old May 25th, 2007, 04:26 PM   #11
sorry about being so confusing. i meant that you don't have to cut the stock wiring harness, but the custom one you make. it's basically making your own y-adapter.
Old June 23rd, 2007, 06:26 PM   #12
WOW, i am confused just looking at what you all posted for this guy/or girl.
rekedevoate is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2007, 07:27 PM   #13
Your V6P Snake Champion
oswhiteboy's Avatar
so you finally decided to get one? Very nice, if it makes a big difference in sq then that might be the next project we do for my car when i come down in July/Aug
oswhiteboy is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2007, 08:00 PM   #14
-Brian
NexsoN's Avatar
nah, im holding off on it, ill get it after i redo my car..
