lost on amps!! - Honda Accord Forum : V6 Performance Accord Forums
Old July 2nd, 2007, 01:24 AM   #1
lost on amps!!
I have a Pioneer DEH-P730 HU, Upgraded front speakers to sony's 60W max, stock rear deck, Eclipse 3640 4/3/2 ch amp. Two Sony XS-1200B subwoofers w/ Box. Traded a pair of old Gotti necklace for the system. My question is would I need another amp to power the subs? Total noob at this. Have googled, and searched here for Two amps, 4/3/2 amp and such... If possible can I run all the speaker off that one amp? if not - fine two amps okay, but How do i send separate signals from the four interior speakers from the subs. HU has 4 preamp outputs. Am I missing something here. I wish I had a block diagram of this for the bigger pic. Thanks.
tarheel4ever is offline   Reply With Quote Quick reply to this message
Old July 2nd, 2007, 09:20 AM   #2
datboiroy's Avatar
Send a message via AIM to datboiroy
i think you could but it wouldnt be enough power to run the subs. id suggest get another amp, run a 2channel rca from the hu to the amp and run the 2 front speakers off that. run your rear speakers off the stock hu wires. then run another 2channel rca from the hu to another amp for the subwoofers, then you should be set.
datboiroy is offline   Reply With Quote Quick reply to this message
Old July 2nd, 2007, 05:04 PM   #3
Would I have to worry about impeadence matching here and just select 2 Ch on the amp?
Old July 4th, 2007, 12:17 AM   #4
You can use the amp you have, but you'd be way better off with a 2nd amp for your subs and using the 4ch amp for your door/deck speakers. I'd replace those rear deck speakers though
That Eclipse amp is rated at 60W RMS per channel and those Sony XS-L1200B subs are rated for 200W RMS & 800W Peak. Its probably not going to hit like you want. (http://www.xplodsony.com/files/manua...ers_Manual.pdf)
To answer your 2nd question: No, impedance isn't a problem. The subs are 4 ohm, after market speakers usually are too (unless they're really high quality).
As far as hooking up a 4ch & a Sub amp to a H/U w/ 4 pre-outs, you'll run 2 pairs of RCA cables to the 4ch. And then 1 pair of RCA from the RCA output on the 4ch to the input on Sub amp.
Make sure you've got a fat enough power and ground wires for the amps, at least 4 gauge. You can get Dual Amp Install Kits. Rockford makes one, but its kinda pricey. (http://www.rockfordfosgate.com/produ...2&locale=en_US)
Nate_6thGen is offline   Reply With Quote Quick reply to this message
Old July 5th, 2007, 01:19 AM   #5
Hey thanks for the info NAte and DAT. I have semi-finished the install this morning at 4 something. Tried to tune it but showed more signes of fatigue by nodding like I was bumping to a song. I have found a FAQ on all audio installation I wish I had found this last week! I will fine tune my radio
http://www.caraudio.com/forum/showthread.php?t=67148
I use firefox so it may not work w/ IE. You may have to sign up for this site when you do the link take you to Car audio Discussion> General Discussion.
It has block diagrams for the Car audio impaired w/ Colors and links as well Yippee!! I hope this link can help anyone else with audio problems. Thanks Again you guys!!!
Last edited by tarheel4ever; July 5th, 2007 at 01:38 AM.. Reason: More info for the website posted
Old July 12th, 2007, 12:43 AM   #6
Just remember, the gain knob on your amp is not a bass boost. Its adjusts the input voltage sensitivity. I think that model of H/U has 4V pre-outs.
