What gauge wire do i need? - Honda Accord Forum : V6 Performance Accord Forums
Old September 10th, 2007, 09:04 AM   #1
EliteCM.net
sy272004's Avatar
i searched for about half hour and couldnt find anything about speaker wires(everything about amps and stuff but no speaker specs)
i ordered Infinity KAPPA speakers from 2 ppl on here, all 4 have 4 ohm resistance. i am hooking them up to factory wiring but i want to run wires to back for future amp installation. what gauge wires do i need? spaekers are 300W max for rear and like 225W for front.
any recomendations? or should i wait with running wires since i would have to take door apart anyway to reconect them
Old September 10th, 2007, 09:39 AM   #2
Senior Member
timot_one's Avatar
Send a message via AIM to timot_one Send a message via Yahoo to timot_one
You should be fine with 18, 16, or 14 gauge wire, anything larger than that would be overkill. You really only need larger gauge speaker wire when you have long runs from the amp to the speaker (i.e. - 50+ feet). The longest run you would have really wouldn't be longer than 15 to 20 feet (depending on how you route it.
Since you're only installing speakers, you're going to be doing a lot of additional work to run those speaker wires. If it was me, I'd wait to run the speaker wires.
timot_one is offline   Reply With Quote Quick reply to this message
Old September 10th, 2007, 10:05 AM   #3
EliteCM.net
sy272004's Avatar
i think somebody mentioned that i can get factory style connectors from circuitcity.com so i dont have cut my factory wires if i decide to put speakers back. but would it hurt if i solder 18, 16, 14 gauge wire to speakers and run it to back and hide it there somewhere for future.
would there be any distortion problems since there other wires attached(but not connected on other end) to speaker in addition to signal wires from factory HU (im just thinking it would create like antena effect or something)
i guess ill go with 16 gauge wires
Old September 10th, 2007, 10:11 AM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
Metro makes the connectors you are talking about, I got mine off the net and were like $10 for 2.
Old September 10th, 2007, 11:03 AM   #5
EliteCM.net
sy272004's Avatar
damn, my store sells wires too. and its gona be cheap as hell on emploee purchase. lets see what we have hehe
my store has pureav by belkin wires for speakers 16 gauge 50' $34.99
http://www.microcenter.com/single_pr...uct_id=0204991
(emploee price $13)
or get couple of this http://www.microcenter.com/single_pr...uct_id=0236480
Emploee price $11 and splice one end into speakers and other would be with rca connector into amp later on?
or get couple of this and splice them
http://www.microcenter.com/single_pr...uct_id=0205736
since its gona cost me $2.54 each
Old September 10th, 2007, 11:19 AM   #6
sittin low
AcCoRd16's Avatar
my whole system is wired to the amps and it doesn't take too long to do
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old September 10th, 2007, 11:22 AM   #7
EliteCM.net
sy272004's Avatar
cool. im sure it doesnt. but it wasnt realy the question
Old September 10th, 2007, 11:23 AM   #8
what's cracking?
16 gauge should be fine.
vietmandomy52 is offline   Reply With Quote Quick reply to this message
Old September 10th, 2007, 11:36 AM   #9
Senior Member
timot_one's Avatar
You can get those connectors from lots of places actually. They're a good option to cutting your OEM connectors.
I wouldn't connect those speaker wires and then just run them to the back of your car. You're going to need to make sure that the ends are terminated properly, otherwise you could possibly damage your OEM radio's amplifier. IMHO, it's a bad idea connect wires that aren't being used. In your effort to be efficient, you're actually going to create more work for yourself.
(emploee price $13)
That speaker wire will work.
That is an RCA cable, not a speaker wire. You cannot connect that to your speakers.
Honestly, that's a bad idea.
Old September 10th, 2007, 02:10 PM   #10
EliteCM.net
sy272004's Avatar
thanks. ill just run wires and leave them unconected, just so they would be in place for future
Old September 10th, 2007, 03:26 PM   #11
datboiroy's Avatar
Send a message via AIM to datboiroy
16awg is good
datboiroy is offline   Reply With Quote Quick reply to this message
Old September 10th, 2007, 11:16 PM   #12
blkb6couper's Avatar
Send a message via AIM to blkb6couper
16 awg is a good size. I always think that a lil thicker wires wouldnt hurt. It's also a good idea to solder your connections once you have everything in place.
blkb6couper is offline   Reply With Quote Quick reply to this message
Old September 11th, 2007, 11:52 AM   #13
7th Gen ACcord
xjdMb16a2six's Avatar
have fun doing that doors.
Old September 11th, 2007, 12:16 PM   #14
sy272004, I dont mean to jack your thread, but do you or any one else here have a suggestion on how to run the speaker wires from inside the cabin out to the doors? Do you use a wire hanger or something? Thanks in advance.
Old September 11th, 2007, 04:22 PM   #15
Blends No. 27
Vestax's Avatar
If you want, check out the tutorial I posted that's stickied in this forum.
Old September 11th, 2007, 04:27 PM   #16
EliteCM.net
sy272004's Avatar
i didnt take apart door yet but i asume run through same rubber boot as other wires for doors go through.
Old September 11th, 2007, 09:51 PM   #17
EliteCM.net
sy272004's Avatar
i looked at all wires and they dont seem to have any insulation except for clear jacket. is it ok?
Old September 12th, 2007, 10:40 PM   #18
7th Gen ACcord
there two ways of doing that. you can half ass it like most audio shops and tap the speakers wires from inside the cabin. and the 2nd way is to use a long zip tie to get the wire through the rubber boot. its a big plus if you have long skinny fingers.
Old September 12th, 2007, 10:41 PM   #19
EliteCM.net
sy272004's Avatar
no half ass job for me. im gona go through rubber boot. do it right or dont do it at all
