need simple wiring help - Honda Accord Forum : V6 Performance Accord Forums
Old September 22nd, 2007, 12:08 PM   #1
Send a message via AIM to yellowfever
i just got a radar detector and i wanna keep it clean so im running the power wire through the map light. I took some pics so if some one could just show me which wire to run which wire to id really appriciate it.
i took the electrical tape off, one of these is positive and one is negative yeah?
heres the power cord from the detector, no ground wire?
Thanks in advance guys
yellowfever is offline   Reply With Quote Quick reply to this message
Old September 25th, 2007, 11:51 AM   #2
Check the manual for the radar detector, one of those if definantly power and ground. I wouldnt recommend splicing into the map button however. If I were you I would just mount the detector high on the windshield and tuck the wires under the headliner towards the a-pilar. From there just run the wires down the a-pillar and ground it directly to the chassis somewhere. As fast as the power wire. You can run it to the fuse block on the driver side right under the a-pillar and hook it up to a acc 12v that turns on with the ignition. I had it setup like this in my supra and it worked excellent. I would just leave my v1 up under the tinted bar accross the top and the detector would just turn on every time I turned the key.
PWNDLOL is offline   Reply With Quote Quick reply to this message
