Can someone pleaser check my wiring quickly - Honda Accord Forum : V6 Performance Accord Forums
Old December 11th, 2007, 08:34 PM   #1
CeRtiFiEd PimP
hey im just wiring my dvc subs first time doing any someone confirm its the right way of hooking it up..the terminals with the white dots are for the first coil...i want to install them right now,,thanks
[IMG][/IMG]
Old December 11th, 2007, 08:50 PM   #2
datboiroy's Avatar
Send a message via AIM to datboiroy
what amp are you using and what is the ohm stable on it. also are the subs dual 4 or dual 2ohm?
if the subs are dual 2ohm and the amp is stable at 2ohm, then you have it wire correct. if the subs are dual 4ohm and your wiring them to the amp if its 4ohm, then ur fine. now if its dual 4ohm and your amp is 1ohm stable, then you have to wire it different. like this...
hope this helps
datboiroy is offline   Reply With Quote Quick reply to this message
Old December 11th, 2007, 09:05 PM   #3
CeRtiFiEd PimP
they are 2ohm subs with a mtx 6001 amp the amp is 2 or 4 ohm stable
Old December 11th, 2007, 09:20 PM   #4
sittin low
AcCoRd16's Avatar
First you wanna wire in series (bring the dual 2ohms up to a total of 4ohms), meaning the red white dot to the black then wire the red and black with white dot out of the box then you wanna wire the subs together in parallel(bring each subs down to a total of 2ohms) the positive to positive and negative to negative. You can also test it with a multimeter just in case if your not sure.
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old December 11th, 2007, 09:41 PM   #5
datboiroy's Avatar
ok, the way you wired them is fine. goodluck on the install.
Old December 11th, 2007, 10:24 PM   #6
CeRtiFiEd PimP
you sayin the way they are pictured is wrong?
