Power Wire in Gen7 Accord - Honda Accord Forum : V6 Performance Accord Forums
Old December 20th, 2007, 08:36 PM   #1
07AV6's Avatar
Where did you route the power wire in your 7th gen Accord? I need to run 4awg through the firewall.
Not finding any info on the 7th gen by searching.
Thanks
07AV6 is offline   Reply With Quote Quick reply to this message
Old December 20th, 2007, 08:40 PM   #2
-Brian
NexsoN's Avatar
Do you have a Manual Transmission, If not, then your in luck.
Use where the clutch pedal would be, there is a rubber gourmet in its place that you can wire through, just slit the groumet.
If you have a MT there is a different solution
Old December 31st, 2007, 12:37 PM   #3
07AV6's Avatar
Thanks.
Where is a good location for the ground wire? The only bolt I see is next to the fuel tank where the sending unit grounds (behind rear seat).
I don't want to drill if not necessary.
Old January 8th, 2008, 07:10 PM   #4
Supernova m33
ngc604's Avatar
Send a message via AIM to ngc604
if you are running 4 gauge then you really need to create a separate ground. using an existing ground is pretty much 80% not to work.
ngc604 is offline   Reply With Quote Quick reply to this message
Old January 8th, 2008, 11:25 PM   #5
07AV6's Avatar
I went ahead and sanded the metal down and mounted the ground on the same bolt a few days ago. I'll check it with a multimeter tomorrow to make sure there's no huge voltage drop. The 4awg was mainly for headroom in the future. I'm only using a 250watt amp for now.
Thanks
Old April 4th, 2008, 06:14 PM   #6
cunning linguist
MorePower4me's Avatar
Just found the thread, sorry to bring it back from the dead...
Whats the solution for a 6 speed??
Old April 20th, 2008, 12:20 PM   #7
probably the same
psyduckiee is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2008, 10:32 AM   #8
sittin low
AcCoRd16's Avatar
there's a hole in the center of the dash covered with a rubber groumet that you can pop off
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old July 19th, 2009, 03:13 PM   #9
Dear god can someone answer where I might run the power wire if I have a 7th gen 5spd coupe? I can't find info on this anywhere!
SuB-CoNsCiOuS is offline   Reply With Quote Quick reply to this message
Old February 15th, 2012, 11:13 AM   #10
^^ same. idk if its the same but i have a 7.5 coupe 5spd manual and couldnt locate an opening in the firewall anywhere.. is there a solution or do i have to bring it to a shop to drill a hole?
Lilxquangsta is offline   Reply With Quote Quick reply to this message
