Register | FAQ | Members List | Calendar | Mark Forums Read | Insurance |
LinkBack | Thread Tools | Display Modes |
#1 |
2006 j32 6 speed manual coupe
Hey guys, selling my av6 6 speed manual. Note, car is in kilometers. I am located in Ontario Canada.
2006 accord v6 6 speed manual coupe. Second owner, thousands of dollars spent on maintenance and repairs. All work was performed by Acura specialist including: New j32a3 motor (3.2L V6 from Acura TL) 120k when installed. Compression test shows motor is extremely healthy. New water pump and timing belt, with new oem coolant replaced at time of engine replacement. Does not leak or burn any oil/coolant. New transmission rebuild only using OEM parts. Third gear recall addressed as well. Synchromesh fluid used in transmission rebuild. New clutch, and "luk" fly wheel. Complete front end suspension rebuild. Including control arms, ball joints, wheel bearings etc. Oil changed every 4K. Car is fully loaded, including sunroof, leather , etc. Everything works as it should. Has upgraded hertz sound system. Body is in good shape, krown rust proofed, hand washed and waxed regularly . Body has 350k. Car runs, and drives excellent. Powerful and very fuel efficient. Only used 91 octane. Have valid E-test. PM for pics, cant' seem to upload here. Thanks
2006 accord v6 6mt one of the best sleepers on the road To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. j32a3 |
Sponsored Links | |||
#2 |
[IMG]
#3 |
Looks clean for the mileage. Any more pics?
Did the original engine start burning oil after 200k miles/350k km or did something else happen to it? |
#4 |
I can post more pics within the next few days. No problem.
Original engine developed piston slap. Surprisingly, it did not eat up any oil before being swapped out.
Sponsored Links | |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
