2005 Honda Accord Hybrid w/Nav $16,500 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > V6P MARKETPLACE > CLASSIFIEDS > CARS FOR SALE
Old November 5th, 2007, 02:17 PM   #1
This is my beautiful Silver Frost Metallic Accord Hybrid with Dark tinted windows. I am trying to sell it because the family has outgrown it (we just bought a Pilot). As is well known this version of the Accord has it positives and negatives, just like with any other car. Some of it's strong points are the performance and luxury. I like it because it can get up and go when needed and when I want to take it easy I can get great gas mileage results.
Here is the Craigslist listing: http://seattle.craigslist.org/sno/car/469513096.html
Here are some specs right off of Honda's web site:
Engineering
Engine Type: V6
Engine Block/Cylinder Head: Aluminum-Alloy
Displacement (cc): 2997
Horsepower @ rpm (SAE net / with IMA): 240 @ 6250 / 255 @ 6000
Torque (lb.-ft. @ rpm / with IMA): 212 @ 5000 / 232 @ 5000
Bore and Stroke (mm): 86.0 x 86.0
Compression Ratio : 10.5 : 1
Valve Train: 24-Valve SOHC i-VTEC®
Multi-Point Fuel Injection
Drive-by-Wire Throttle System™
Idle-Stop Feature
Variable Cylinder Management™ (VCM™)
Active Control Engine Mount System (ACM)
Active Noise Cancellation (ANC)
CARB Emissions Rating: ULEV-2
Direct Ignition System with Immobilizer
Tune-Up Interval*: 105,000 Miles
* Does not apply to fluid and filter changes. See Owner's Manual for details.
Transmission
Compact 5-Speed Automatic Transmission
1st: 2.685
2nd: 1.565
3rd: 1.023
4th: 0.729
5th: 0.530
Reverse: 1.888
Final Drive: 4.375
Electric Motor / Generator
Permanent Magnet Motor
Power Output: 16hp @ TBDRPM
Motor Width (mm): 68
Electric Power Storage
Nickel-Metal Hydride (Ni-MH) Battery
Output: 13.8Kw
Rated Capacity: 6.0Ah
Body/Suspension/Chassis
Unit-Body Construction
Double Wishbone Front Suspension
Five-Link Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear) : 25.4 / 14.0
Electric Power-Assisted Rack-and-Pinion Steering (EPS)
Steering Wheel Turns, Lock-to-Lock: 3.17
Steering Ratio: 16.25
Turning Diameter, Curb-to-Curb (ft.): 36.1
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes
Wheels : 16" Lightweight Alloy
All-Season Tires: P215/60 R16
Interior Measurements
Headroom (in., front/rear): 40.4 / 38.5
Legroom (in., front/rear): 42.6 / 36.8
Shoulder Room (in., front/rear): 56.9 / 56.1
Hiproom (in., front/rear): 54.6 / 53.5
Cargo Volume (cu. ft.) : 11.2
Passenger Volume (cu. ft.): 102.7
Seating Capacity: 5
Exterior Measurements
Wheelbase (in.) : 107.9
Length (in.): 189.5
Height (in.): 57.1
Width (in.): 71.5
Track (in., front/rear) : 61.1 / 61.2
Curb Weight (lbs.) : 3501
Coefficient of Drag: 0.29
EPA Mileage Estimates*/Capacities
5-Speed Automatic Transmission (City/Highway): 29 / 37
Crankcase (qt.): 5.3
Coolant System (qt.): 9
Fuel (gal.): 17.1
Required Fuel: Regular Unleaded
*Based on 2005 EPA mileage estimates. Use for comparison purposes only. Actual mileage may vary. :
Safety
3-Point Seat Belts at all Seating Positions
Front 3-Point Seat Belts with Automatic Tensioning System
Adjustable Front Seat Belt Anchors
Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS)
Side Curtain Airbags
Anti-Lock Braking System (ABS)
Electronic Brake Distribution (EBD)
Traction Control System (TCS)
Side-Impact Door Beams
Lower Anchors and Tethers for Children (LATCH) (rear): Outboard
Rear-Center Child-Seat Tether Anchor
Child-Proof Rear Door Locks
Immobilizer Theft-Deterrent System
Emergency Trunk Opener
Exterior Features
Alloy Wheels: 16" Lightweight Alloy
Security System
Remote Entry System with Power Window Control
Variable Intermittent Windshield Wipers
Rear Decklid Spoiler
Multi-Reflector Halogen Headlights: with Auto-off
Body-Colored Dual Power Mirrors
Body-Colored Body Side Molding
Body-Colored Door Handles
Body-Colored Impact-Absorbing Bumpers
Chrome Window Trim
Comfort & Convenience
Dual-Zone Hybrid Automatic Climate Control System
Honda Satellite-Linked Navigation SystemTM with Voice Recognition: Available
Power Windows with Auto-Up/Down Driver's Window
Illuminated Power Window Switches
Power Door Locks
Cruise Control
Leather-Wrapped Steering Wheel
Illuminated Steering Wheel-Mounted Controls
Tilt and Telescopic Steering Column
HomeLink® Remote System†
Premium Interior Accents
Center Console with Sliding Armrest and Storage Compartments
Beverage Holders, Front and Rear (8 Total)
Driver's and Front Passenger's Illuminated Vanity Mirrors
Ambient Console Lighting
Map Lights
Sunglasses Holder
Coin Box
12-Volt Power Outlets (2 total)
Lockable Glove Compartment with Light
Remote Fuel Filler Door Release
Remote Trunk Release with Lock
Electronic Remote Trunk Release
Rear Window Defroster
Cargo Area Light
Floor Mats
Side Door Pockets with Integrated Beverage Holder, Front and Rear
† HomeLink® is a registered trademark of Prince Corp. a wholly-owned subsidiary of Johnson Controls.
Seating
Leather-Trimmed Seats and Door Panel Inserts
Heated Front Seats
Driver's Seat with 8-Way Power Adjustment
Audio Systems
120-Watt AM/FM/6-Disc In-Dash CD Changer Audio System: with 6 Speakers
XM® Satellite Radio
Instrumentation
Progressive Self-Illuminating Gauges
Tachometer
Idle-Stop Indicator Light
IMA Charge and Assist Indicators
Battery Charge Indicator
Digital Odometer and Digital Trip Meters (2)
Door-/Trunk-Open Indicator Light
Fuel and Coolant Temperature Guages
Low-Oil Pressure and Brake Fluid Indicator Lights
Maintenance Interval Indicator
Quartz Digital Clock
I also have to say this car has been reconstructed after an accident. So the title is branded. Shouldn't be a big issue since it was professionally repaired by a local shop.
Anyways, since I really need to sell it NOW I am willing to negotiate. $16,500 is the asking price. If interested please get in touch with me at 541-967-4822 or email [email protected]
yurashichka is offline   Reply With Quote Quick reply to this message
