3800 to 3.8 swap - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > OTHER V6 AUTOMOBILE DISCUSSION > GM, GMC, and PONTIAC
Old April 10th, 2006, 06:09 PM   #1
3800 to 3.8 swap
Hi, I have a 1995 buick lesabre with 3800 (rod knocking).I also have 1988 olds ciera with buick 3.8 buick (bad fuel pump).I would like to know if basic short blocks are same. I would like to replace 3800 with the 3.8 and use 3800 exterior engine parts on 3.8.Is this possible?Please help: Earnhardt fan
earnhardtfan is offline   Reply With Quote Quick reply to this message
Old April 10th, 2006, 06:33 PM   #2
Formerly VTEC-v6!
N54TT's Avatar
Thread moved
Welcome to V6P, and good luck with the swap...sorry I don't have the answer you're looking for though
Garage:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2017 Chevy Tahoe LT
Gone but not forgotten:
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
Old April 10th, 2006, 09:02 PM   #3
BULLPOO
SixSpeeder's Avatar
you might want to check with smog laws in your area too. here in california, if you do a motor swap, the motor has to be the same year or newer than the car you are moving it to for cars post 1972.
Old April 10th, 2006, 10:01 PM   #4
"Certified Hybrid Killer"
SteVTEC's Avatar
there aren't any 3800 tech heads here that I know of, but definitely give www.clubgp.com a try.
Old May 4th, 2006, 09:48 PM   #5
NEvans
Send a message via AIM to soldierdude262
Is that cierra front drive? I thought the 3.8 was in rear drive platforms, like the V6 camaros and firebirds, and the 3300 and 3800 (these 2 are interchangable) were for front drive platforms, cause my '90 cierra was front drive with a 3300. I've heard that the 3.8 and 3xxx series are very different, not even sharing the same block angle (3.8 is 60, 3xxx is 90).
Old May 4th, 2006, 10:53 PM   #6
That one guy
BadgerType's Avatar
Send a message via AIM to BadgerType
3800 is both engines (85% sure)
both gm made so im pretty sure there both interchangable
BadgerType is offline   Reply With Quote Quick reply to this message
