dreamer needs a chop! - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > GENERAL DISCUSSION > RANDOM CHATTER > TECHNOLOGY CORNER > GRAPHIC DESIGN and ART
Old September 4th, 2007, 04:47 PM   #1
Official V6P Retro Whore
dreamer's Avatar
Somebody with some photosexshop skills can chop these wheels on an 03-05 silver 'ccord.
I'm not sure who's 'ccord this is, but thanks
Rims!
These will be 20x8.5 +35 w/235/30/20 wheels.
Guy says they will fit hmmm
Thanks!
dreamer is offline   Reply With Quote Quick reply to this message
Old September 4th, 2007, 05:00 PM   #2
datboiroy's Avatar
Send a message via AIM to datboiroy
no way!!!! they will not work
datboiroy is offline   Reply With Quote Quick reply to this message
Old September 4th, 2007, 05:01 PM   #3
Adventure is out there!
littletruong's Avatar
those won't fit
Old September 4th, 2007, 05:02 PM   #4
V6p OG
XxAznJoexX's Avatar
run a lower profile tire and it will work
do a 225 instead of a 235
&mpt=[CACHEBUSTER]">
.:Nextstage Accord:.:Meguiars 2007-08:.:Nitto Tires:.:
XxAznJoexX is offline   Reply With Quote Quick reply to this message
Old September 4th, 2007, 05:31 PM   #5
ASAGA1's Avatar
Originally Posted by littletruong View Post
those won't fit
True.......true................
ASAGA1 is offline   Reply With Quote Quick reply to this message
Old September 4th, 2007, 06:32 PM   #6
dreamer's Avatar
Ya, this guy is trying to convince me it will work, but I've seen too many threads about 20" needing +42 and above.
As for the 225, I'll check it out
Thanks for all the help
Old September 4th, 2007, 06:43 PM   #7
Moderator
00Accord4cyl's Avatar
Dang getting that low of an offset is smaller wheels is going to be pain enough to fit..but in 20's...wow i wouldnt' think that would be possible at all..but hey..what do i know..nada
00Accord4cyl is offline   Reply With Quote Quick reply to this message
Old September 4th, 2007, 06:54 PM   #8
dreamer's Avatar
He mentioned they could shave the wheels down? I guess that means they could make it a higher offset? Something in the neighborhood of +42 +44
Anybody have experience in shaving wheels down?
Old September 5th, 2007, 04:43 AM   #9
dreamer's Avatar
bump! still need chop!
Old September 5th, 2007, 05:53 AM   #10
Growth Chart Specialist
Shenaniganz08's Avatar
can you get me a front picture of the rim, this should be a quick shop
Old September 5th, 2007, 03:10 PM   #11
dreamer's Avatar
Ya, they only have side shots I tried doing it myself, but I couldn't compensate for the side shot.
Old September 5th, 2007, 03:11 PM   #12
dreamer's Avatar
I was checking into getting these too
Old September 5th, 2007, 03:34 PM   #13
MADE IN THE PHILIPPINES
aV6Pinoy's Avatar
damn, i don't think that would work. unless if you had a freakin' 7.5width rim. or a 8.5 with atleast a +42 offset.
i wouldn't do it. but if you want to, go with 225-35 profile. just don't drop it too low. leave atleast an inch and a half of gap.
aV6Pinoy is offline   Reply With Quote Quick reply to this message
Old September 5th, 2007, 08:49 PM   #14
dreamer's Avatar
I'm actually dropped on H-techs with an ingalls rear camber kit. I'm told that once the 20" are on, I'll need to remove the camber kit. But the current drop should be ok.
