TL-S Sway Bars.. - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > Vendors > Park Acura
Closed Thread
Old February 28th, 2011, 07:18 PM   #1
TL-S Sway Bars..
Hello,
I'm looking for the following for my 2006 Honda Accord I-4 Coupe (LX). I pretty much copied and pasted the info from the TL-S Sway Bar Thread. Please let me know if the quantities of the parts look right, or if they are not needed (such as the bolts/brackets).
Front TL-S 27.2mm
(4) - 90120-SEP-A00 BOLT, FLANGE (10X35)
(2) - 51308-SDA-A00 BRACKET, FR. STABILIZER
(2) - 51306-SEP-A01 BUSH, FR. STABILIZER HOLDER (27.2MM)
(1) - 51300-SEP-A01 SPRING, FR. STABILIZER
Rear TL-S 20mm
(4) - 93402-08016-08 BOLT-WASHER (8X16)
(2) - 52306-SEP-A11 BUSH, RR. STABILIZER HOLDER (20MM)
(2) - 52308-S3M-A00 HOLDER
(1) - 52300-SEP-A11 SPRING, RR. STABILIZER
Thanks for your help in advance, and I can order as soon as tonight or tomorrow morning.
-Amar
dblock2151 is offline   Quick reply to this message
Old February 28th, 2011, 07:19 PM   #2
Oh, and my zip code is 06111.
Old March 1st, 2011, 09:41 AM   #3
Park Acura
SanMarino Coupe's Avatar
Send a message via AIM to SanMarino Coupe
$177 Shipped
SanMarino Coupe is offline   Quick reply to this message
Old March 1st, 2011, 11:13 AM   #4
I will need the bolts then correct? Thanks!
Old March 2nd, 2011, 07:48 AM   #5
Park Acura
I would replace them
Old March 2nd, 2011, 11:17 AM   #6
gen_unknown_7.5's Avatar
Dont wanna thread jack, but does that mean i should have ordered the bolts as well?
gen_unknown_7.5 is offline   Quick reply to this message
Old March 3rd, 2011, 10:18 AM   #7
Park Acura
It all depends on the area of the country you live in.
Old March 3rd, 2011, 01:58 PM   #8
I think I messed up, I wanted the solid 27mm bar, not the hollow 27.2mm. Would you happen to know the part number for the solid bar?
Also, would the bushings/bolts from the 27.2mm bar work for the solid 27mm bar?
Old March 5th, 2011, 01:47 PM   #9
Park Acura
51300-SEP-A21 That bar is actually $40 cheaper then the hollow one
Bushings are the same
Old March 5th, 2011, 02:19 PM   #10
^Thank you for all your help! Placing the order now.
Old March 5th, 2011, 02:49 PM   #11
Just placed the order and the total came out to $128.36 shipped. I was expecting it to be around $137.00 shipped but was pleasantly surprised! Did the discount already take effect?
Thanks again!
Old March 7th, 2011, 07:25 AM   #12
Park Acura
Yep you are discounted
Old March 8th, 2011, 12:15 AM   #13
girl powah!!
03aV6cpe's Avatar
Right on!
Don't forget to leave joe feeeeedback
03aV6cpe is offline   Quick reply to this message
Closed Thread
