E-code headlamps? - Honda Accord Forum : V6 Performance Accord Forums
Old September 7th, 2003, 03:07 AM   #1
E-code headlamps?
kind of a weird question but, the beams on my lexus rx300 without HIDs seem to have a diagonal flare to it?!?!?! is that e-code lamps, is this normal??? is anyone else's car like this? this is my first encounter with this kind of beam, i have own toyotas before, but this is weird.....
J30A02 is offline   Reply With Quote Quick reply to this message
Old September 22nd, 2003, 06:33 PM   #2
Senior Member
VTEC_V6's Avatar
Send a message via AIM to VTEC_V6 Send a message via Yahoo to VTEC_V6
No it is not an E-Code headlight. It just has a distinctive light beam cut off. I saw an RX 300 with an HID retrofit and the glare was quite noticeable campared to an RX 300 with Stock HID's. I do believe however that all Lexus vehicles with stock HID's have E-Code headlamps with automatic levelers. The beam pattern cut off on HID cars are super sharp and have no glare.
-=Lex Tech=-
VTEC_V6 is offline   Reply With Quote Quick reply to this message
Old September 23rd, 2003, 02:09 AM   #3
thats the thing tho....i only have stock bulbs...not HIDs on mine
Old September 23rd, 2003, 05:17 AM   #4
Senior Member
VTEC_V6's Avatar
Your RX 300's light beam flares out and up to the right; I've seen it and understand what you're talking about. Most car manufacters now are creating better beam patterns with thier NON HID lights in an attempt to further reduce glare. If you don't believe me compare your lights side-by-side with an RX 300 with HID's and you'll notice how much different the cut off is up against the wall, or (if you're brave enough ) by looking into the headlight with the lights on you can even see how the HID shield does not allow any light on the bottom portion of the reflector.
-=Lex Tech=-
