Supra Engine Help - Honda Accord Forum : V6 Performance Accord Forums
Old May 19th, 2008, 04:56 PM   #1
Supra Engine Help
What is the different between the 2JZ GTE and 1JZGTE?
I know nothing about supra engine. I am planning buying a supra (maybe with stock turbos)and boost them with larger turbo. If I can't find the supra, my other option is that I will get the lexus SC and throw the supra motor in it.(don't know which one will be good for the supra motor,300 or 400)
my question are:
which motor will be good for the Lexus SC?
and which SC will I get?
I really need your help. thanks.
02SilverAcc2dr is offline   Reply With Quote Quick reply to this message
Old May 19th, 2008, 09:59 PM   #2
J32A2 + SC + Meth AV6
BlackV62K2's Avatar
Main difference 1JZ is a 2.5L motor and 2JZ is a 3.0L motor.
Old May 19th, 2008, 11:14 PM   #3
thread killer
where are you located? you want to buy my sc?
Old May 20th, 2008, 01:01 PM   #4
weezo's Avatar
Better put the ghallow 24 instead
weezo is offline   Reply With Quote Quick reply to this message
Old May 20th, 2008, 01:47 PM   #5
Bobby Lane Racing
nighthawk04v6's Avatar
i'm dropping a 2jz-gte in a 95 SC if you can get your hands on a 5spd sc300 than the tranny bolts right on, if you have a 400, you'll have to get an entire front clip of either 1jz-gte or 2jz-gte.
Old June 11th, 2008, 12:17 AM   #6
is there jza80 in the us?
holden kurt is offline   Reply With Quote Quick reply to this message
Old June 11th, 2008, 12:45 AM   #7
The 1JZ is a 2.5L while the 2JZ is 3.0L
The 1JZ Can hold power reliability at 550WHP compared to the 2JZ Ive seen 4 digits on a stock motor(Dosent last as long).
I recommend doing the 2JZ, but 1JZ would be the same.
It dosen't matter what motor you want to drop in a SC, its more about what your power goals are. In swapping the 2JZ in a SC(Project on hold)the swap itself is a complete drop in but only in the SC300. In the SC400 mounts need to bought, much more wiring(V8), and all that hassle isnt worth it. If you do planning on dropping it in the SC300 the only thing youll need is to swap out the GTE oil pan to the GE oil pan(Clerance Problems).
WhiteAcord is offline   Reply With Quote Quick reply to this message
Old August 8th, 2008, 12:36 AM   #8
2jz is the way to go man i have one and its a beast!
550whpAV6 is offline   Reply With Quote Quick reply to this message
Old January 13th, 2009, 05:22 PM   #9
Lots of misconception here.
The record for a 1jz (stock block) is around 900whp, and it's just as potent as the 2jz, just has less displacement.
In an SC, the 1jz is a direct drop in and is plug and play. That's why I have one in my car. 2jz requires custom wiring to the body plugs. SC300 and SC400s are nearly an identical swap. The main differences are the driveshaft, differential, and mounts.
Also, the 2jz bottom end bolts right on to the 1jz head. Virtually everything is interchangable.
tavarish is offline   Reply With Quote Quick reply to this message
Old February 9th, 2009, 02:18 PM   #10
lol there is no such a thing as a manual sc3 or 400 you can convert it, put an is300 trans or supra? the sc already comes with a 2j just not built for turbo. You can build it for turbo but it might be more costly and less reliable. the best thing you can do is get a 300 rather than a 400 (in most cases cheaper) and then swap it out. but it is more than possible to turbo up your stock 2jzge and make it a 2jzgte
MackinLexS is offline   Reply With Quote Quick reply to this message
Old February 9th, 2009, 02:30 PM   #11
Bobby Lane Racing
your an idiot. there are manual SC300's factory, and I have one.. You still are an idiot for posting like you know something.
the 2JZGE's intake manifold overlaps the valve cover and rides over the exhaust side. It would be stupid to try and turbo charge that motor when you can acquire a front clip 2jzgte for under $2200. You would need a turbo intake manifold, a turbo exhaust manifold, a turbo, management, run oil lines to and from turbo etc. WHICH WILL COST MORE THAN purchasing a an entire 2jzgte front clip.
Stop being an idiot and post whoring like you know something so you can build enough post to start your own thread. IDIOT
Old February 9th, 2009, 02:37 PM   #12
owned
Old February 9th, 2009, 03:23 PM   #13
07' V6 Auto Sedan
dnlgao's Avatar
Send a message via AIM to dnlgao Send a message via MSN to dnlgao
WhoooPSH!
dnlgao is offline   Reply With Quote Quick reply to this message
Old February 9th, 2009, 05:03 PM   #14
Thumbs up
thats how you learn things? thanks for being so helpfull ahah and btw i didnt recomend he turbo the car if you read. where can i get a cup of hateraide from around here?
Old February 9th, 2009, 06:33 PM   #15
ex scientia vera
kramer2k's Avatar
your an idiot.
Old February 9th, 2009, 07:17 PM   #16
07' V6 Auto Sedan
dnlgao's Avatar
Wow?
Old February 9th, 2009, 08:07 PM   #17
BULLPOO
SixSpeeder's Avatar
nighthawk... relax buddy. k?
Perhaps you should slow your roll. Don't just post the words that in your head. Obviously it has done you wrong in the past and will do you wrong in the future. Also, if you keep post whoring like this, I'll delete your for sale thread and set your post count to -600 so I wont have to worry about you making another thread or PMing anyone for a very long time.
Originally Posted by kramer2k View Post
your an idiot.
lol... Gets me everytime.
Old February 9th, 2009, 08:09 PM   #18
-Maninder
Gallo*
Lol
Am I the only one who got the F&F reference?
Old February 9th, 2009, 08:15 PM   #19
BULLPOO
SixSpeeder's Avatar
That's why you need Rome Pierce as your sidekick wheel man.
Old February 9th, 2009, 09:23 PM   #20
Bobby Lane Racing
sorry, i'll keep the tone down. It was just a little funny for a aristo owner to come around and say the usdm soarer didn't come manual so I had to make him stnnd out a little, and for post whoring so he can do FS thread made me bring out the best in him. you know me.. and i pick on noobs. jk love you guys!
