Camry SE V6 (3MZ-FE) Tranny Issues? - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2004, 10:12 PM   #1
has anyone else noticed that their tranny kinda "lags"? meaning that whenever it should shift, it takes about a second or two to actually shift (downshift, upshift, the works). for example, im taking a turn and when i get back on the gas after the "apex", the engine revs a little but doesnt go any faster, like its in neutral or something. when it finally shifts, its really jerky. another example: accelerating from a stop. when i give the car some gas, the car creeps ahead, engine revs to about 2k-3k rpm and then starts accelerating like a normal car would.
has 3500 miles after some Moderate-Aggressive driving, but this has been going on since Day 1.
ricerokets4life is offline   Reply With Quote Quick reply to this message
Old May 31st, 2004, 12:45 AM   #2
J30A1 => J30A5 => K24Z3
TH23's Avatar
It sounds like your transmission is slipping. A little bit of slippage off the line by the torque converter is normal but slipping during shifts isn't. Our RX330 doesn't have that problem (yet, knock on wood really fast), but I've read that many low-mileage RX330's have had to have their trannies replaced. Since the new Camry SE shares the same drivetrain as the RX, it's safe to assume that it has a similar chance of developing tranny issues.
Take your car to the dealer ASAP because there's no excuse for a new car to shift like that. Good luck!
Old May 31st, 2004, 09:38 AM   #3
ECT-i... electronically control throttle blows... it feel as if you're lagging when you floor it... the response is bad, but after the "lag" it's a good thing.
xravexboix is offline   Reply With Quote Quick reply to this message
Old May 31st, 2004, 07:00 PM   #4
Lumpy's Avatar
Go to page 2, its been discussed under 3.3 tranny lag or something like that!!!
Lumpy is offline   Reply With Quote Quick reply to this message
Old May 31st, 2004, 07:07 PM   #5
Re: Camry SE V6 (3MZ-FE) Tranny Issues?
Is the shifting jerky or just the way it accelerates? If it's the shifting then you might be having tranny problems. The rest sounds like what xravexboix said, the ECT-i.
Old May 31st, 2004, 07:17 PM   #6
Formerly VTEC-v6!
N54TT's Avatar
Heh, I got the electro throttle in my Solara SE...It's even worse when you only have 163 lb-ft to play with in the first place
Garage:
  • 2017 Chevy Tahoe LT
  • 2016 BMW 535i M-Sport
Gone but not forgotten:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
Old May 31st, 2004, 08:26 PM   #7
hahaha it's so true!!! At least my Solara weighs like 2 lbs less =P
Old May 31st, 2004, 10:42 PM   #8
TH23's Avatar
True, but I bet it still pulls harder in the low-end than your AV6
Old May 31st, 2004, 10:51 PM   #9
SO TRUE !! !! !! LOL
Old June 1st, 2004, 01:55 PM   #10
Formerly VTEC-v6!
N54TT's Avatar
You know whats sad, is how anything under 4000, the Solara dominates my AV6
Garage:
Old June 1st, 2004, 02:16 PM   #11
TH23's Avatar
That is sad I was pretty sure that was the case based on my CarTest simulations. Unlike the J30A1 or any other Honda SOHC VTEC-E engine for that matter, VVT-i engines have most of their torque available just off-idle. The 3MZ-FE is a good example because that sucker pulls hard all over the power band, even below 2k rpm in our 3900lb RX
Old August 22nd, 2004, 08:40 PM   #12
Same thing with the 1MZ-FE with the five speed, It is probably caused by the drive-by-wire design, the five speed does not seems to help either.
This design may benefit things like VSC and cruise control etc., but the trade-off far out weights the benefit.
Not sure if a fix is on the way any time soon, the dealer is still calling this phenomenon "normal".
cam3r is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2004, 09:55 PM   #13
TH23's Avatar
The throttle lag is the main reason I don't really like driving my mom's RX330. Having to wait for the car to respond to throttle input gets old really fast. The ETC spends too much time trying to figure out what you want it to do instead of actually doing it. I'm sure people get used to it (my mom hasn't complained about it but that's probably because her old car, a 2000 Passat, also had ETC) but on the rare occasion that I drive the RX330, it requires a bit of adjustment not to mention patience .
Old August 25th, 2004, 09:47 PM   #14
Just a Regular Member now
Send a message via AIM to Dizzy
I've noticed if I used 93 octane and drive w/ a lead foot, the lag disappears for the most part. Then the pedal is really sensitive and there is no more lag. I guess the ecu learned my driving style
Dizzy
Dizzy is offline   Reply With Quote Quick reply to this message
Old August 27th, 2004, 09:45 AM   #15
yeah its jerky only when downshifting.
Old August 29th, 2004, 07:17 PM   #16
After reading many related complaint from various sites, it appears that the delay is caused by the drive-by-wire design and the new five speed tranny does shift roughly some times.
Many Gen-5 owners did not notice it, probably because Camry is still a better car by comparison, but owners of previous generation Camry will notice it from day one.
Old October 15th, 2004, 08:53 PM   #17
Original Member
I've had my 03 SE V6 since may 2003, so its the mid year change one with a 5 speed overdrive auto tranny with 210 hp and 220 tq. and I have almost 40,000 miles on my car and my tranny does not slip, I drive it hard everyday, and I've been manually shifting it even before I broke it in, heh. starting at like 700 miles. I abuse my auto tranny like no other. it doesn't slip but it does lag a little
drive4aliving is offline   Reply With Quote Quick reply to this message
Old October 15th, 2004, 10:34 PM   #18
40k; dang that's quite a bit of miles there buddy
vvt-i is offline   Reply With Quote Quick reply to this message
Old October 15th, 2004, 11:19 PM   #19
nycsam786's Avatar
Send a message via AIM to nycsam786
lots o miles
nycsam786 is offline   Reply With Quote Quick reply to this message
Old October 18th, 2004, 05:48 AM   #20
Original Member
yea I know, my family puts miles on cars like crazy
Old October 23rd, 2004, 08:09 PM   #21
wow, i don't know toyota's tranny slips too??
Icen is offline   Reply With Quote Quick reply to this message
Old October 25th, 2004, 06:15 AM   #22
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
shiiiiet , i dont even know where my older sister drives , got her Camry last year and it has just about 20,000 miles on it . 20,000 in a year? .. isnt an average number like 12k a year?
Old October 25th, 2004, 09:21 AM   #23
Just depends I guess... I've had my Camry for over a year, bought it in CA and drove it to ut, now it's 20+ miles already. however, my uncle that purchased the camry the day before me has over 26-28k+ and he commutes a lot back and forth for his work, errands, go out to eat etc etc... As for me, driving to school and home is around 55-65 miles round trip.
