How strong is the 2JZ-GE engine? - Honda Accord Forum : V6 Performance Accord Forums
Old June 1st, 2003, 09:54 AM   #1
I have that in my GS3 and i know its a stout block. But how stout is it really? I mean how much HP can it make w/o changing any internals?
Also, the auto tranny in that car, I know it can be built up unlike the av6 trannies. But how much HP can these auto trannies handle w/o dying? Lastly, does the GS3 and the GS430 share the same auto tranny?
unsure is offline   Reply With Quote Quick reply to this message
Old June 1st, 2003, 10:11 AM   #2
Just swap in a 2jz- gte! and boost away!
hkspower is offline   Reply With Quote Quick reply to this message
Old June 1st, 2003, 09:36 PM   #3
Tune your fuel and spark well and i'd say you'd be fine to 350-400hp depending on mileage.
VaV6 is offline   Reply With Quote Quick reply to this message
Old June 17th, 2003, 10:49 PM   #4
Some people have hit close to 600whp with it.
IS300Turbo is offline   Reply With Quote Quick reply to this message
Old June 17th, 2003, 10:52 PM   #5
Stock internally?
What setup you runnin bro?
Old June 18th, 2003, 12:08 AM   #6
:werdL
STOCK?!?!?!!!
Old June 18th, 2003, 12:11 AM   #7
Senior Moderhater
abram2001's Avatar
turbo, turbo, turbo
pshhhh pshhhhh
Old August 30th, 2003, 08:42 PM   #8
The 2JZ-GTE motor can be tuned to 1000+hp
http://www.suprastore.com/stag8upkit12.html
Jaspher is offline   Reply With Quote Quick reply to this message
Old August 31st, 2003, 08:49 AM   #9
Senior Member
VTEC_V6's Avatar
Send a message via AIM to VTEC_V6 Send a message via Yahoo to VTEC_V6
The 2JZ-GE is a fairly stout engine. 400 HP should be nothing for it to hold. Because that's what the stock tranny is good for ... roughly 400 HP. Expect a shorten life out of the tranny though unless you're considering an upgrade.
-=Lex Tech=-
VTEC_V6 is offline   Reply With Quote Quick reply to this message
Old September 11th, 2003, 08:58 PM   #10
the w55 (stock IS 5spd tranny) has been known to break at a low 340whp where the auto trannies for the IS can hold up to about 400whp
an IS member swapped a W58 tranny (i think SC 5spd) for abtou 600 bucks with 60K miles on it.
i would assume the stock GS3 tranny would hold about the same.
the motor would be good for at least 500whp on stock internals
kuuligan is offline   Reply With Quote Quick reply to this message
Old September 15th, 2003, 10:06 PM   #11
well worth it... someone mated a 2jz-gte in a tacoma... but they're having trouble going straight...
AFP520 is offline   Reply With Quote Quick reply to this message
Old September 25th, 2003, 12:32 PM   #12
PFS hit 600whp on a stock transmission and stock internals in a Lexus IS300.
Old September 25th, 2003, 12:58 PM   #13
hey is300turbo..............any chance ur name is David from NY?
13lizzard is offline   Reply With Quote Quick reply to this message
Old September 25th, 2003, 01:09 PM   #14
It's a possibility.
Old September 25th, 2003, 01:27 PM   #15
this is Johnny99 or 2003accordV6 from Montrealracing.com...................dont worry i am not stalking you
Old September 25th, 2003, 04:49 PM   #16
What's up!?
Old September 25th, 2003, 06:00 PM   #17
yea, but the tranmission didnt last too much longer
its ok tho, the IS'ers know the W55 tranny is a pos anyways. The R154 tranny upgrade can be acquired for pretty cheap. I think doublin from is300.net blew his tranny with SRT stageII
Old October 21st, 2003, 12:49 AM   #18
Put in an Aristo drivetrain.
AREITU is offline   Reply With Quote Quick reply to this message
Old October 21st, 2003, 01:27 AM   #19
the aristo drivetrain is for an automatic
Old January 16th, 2004, 12:20 AM   #20
sc300
i know the sc300 pushes out 225 hp and the same engine in the supra NA pushes out 5 hp less for some reason.
kentaro35 is offline   Reply With Quote Quick reply to this message
Old January 16th, 2004, 12:21 AM   #21
sorry in the last post i ment 225! sorry bout that
Old January 16th, 2004, 12:32 AM   #22
"Certified Hybrid Killer"
SteVTEC's Avatar
just hit the edit button and you can edit your posts
Old January 30th, 2004, 08:29 PM   #23
Vimal (vee-mall)
KnightRyder's Avatar
my friend has an amazing is300 with a 2JZ-GTE motor in it, bad a$$ power, it's out of commision right now for some upgrades, but man that suka is FAST!
Old March 22nd, 2004, 09:03 PM   #24
bryan <3's bomex
mastadulog's Avatar
this makes me wanna ditch my car for an auto supra
psh psh
Old March 29th, 2004, 06:25 PM   #25
I put 321 to the wheels with a Stage I turbo. With a TT bottom end, I know a few guys putting down 5-600 rwhp.
actolex is offline   Reply With Quote Quick reply to this message
Old April 29th, 2004, 01:27 AM   #26
GS4 tranny is good up to 550 hp
SRT got a couple of them running around on stock tranny
but people upgrade tranny cause it feels way sluggish with that much power. hell my tranny feels sluggish with nearly stock power.
NudeGS4 is offline   Reply With Quote Quick reply to this message
Old May 9th, 2004, 07:27 AM   #27
well there is a SC300 that sits in my driveway that puts down 400 to the wheel the stock 5 spd tranny with an clutchmasters stage 4 clutch.
BoroGS300 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2004, 11:39 PM   #28
go check out is300.net they have a lot of info there. lower the compression a little and u should be able to have over 450rwhp
y0aznmasta is offline   Reply With Quote Quick reply to this message
Old June 11th, 2004, 09:55 PM   #29
Formerly VTEC-v6!
N54TT's Avatar
Guys lets not forget there ARE some differences between the -GE and the -GTE motors. The 600whp stock internal numbers are seen on the -GTE internals, not the -GE's.
But the -GTE bottom end is a fairly cheap replacement from the used toyota parts bin
Garage:
  • 2017 Chevy Tahoe LT
  • 2016 BMW 535i M-Sport
Gone but not forgotten:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
Old August 6th, 2004, 03:04 AM   #30
The problem with the 1998 and up models GS300 is that the engine runs on digital signals while the supra GTE motor uses analog signals, you would have to rewire the entire car, and many of the electronics inside would not function. You could do a JDM Aristo swap, but the harness for the engine does not line up with the USDM harness, so there would be trouble in that. The GE motor in the GS can handle a small amount of boost but the fuel map would have to be retuned to adjust for the VVT-i since the valve timing would cause the fuel map to run dangerously lean in the upper rpm band and the chances of causing detonation would be quite high.
The only reliable option would be either have the harness AND the jdm motor swap, or have the engine fully rebuilt and tuned. The GS300 4spd tranny can handle up to 450 hp, the GS300 5spd can handle 400hp.
option 3 (the unspoken option): buy a pre-1998 SC300 and it is a direct swap for the turbo supra GTE motor, transmission, and other components, tune for an amazingly fast lexus.
btw, i own a 1998 GS300 and asked around for the price of turbo build ups and engine swaps, price: 12,000 to 16,000... having a 4000lb sedan that can spank ricers everywhere...priceless.
-t a k t i k s- is offline   Reply With Quote Quick reply to this message
