help, mom in accident - Honda Accord Forum : V6 Performance Accord Forums
Old September 21st, 2005, 04:40 PM   #1
4 bangin'
Sketch o5's Avatar
hey guys, i own a 98 accord, but my moms got a 00 camry 4 banger and she got in a little accident today. everything wil be fine, nothings dented anymore, i fixed that, and scratchs are out too, but i need a passenger side headlight and corner light. what i need to know is where the cheepest place i can get those from? i also need to know where i could get directions on how to replace the healights and the corner light, cuz theyre both busted up. thanks in advance......if i dont check up on this thread, PM me please, im forgetful most of the time, haha.
Old September 21st, 2005, 05:00 PM   #2
Talking
Ebay for sure.
wht/accord99v6 is offline   Reply With Quote Quick reply to this message
Old September 21st, 2005, 05:07 PM   #3
J33 w/TL LSD 6 Speed
05AV6's Avatar
with regards to the removing the corner lamp (I had a 99 camry 4 banger) you should see a plastic hanger coming out from the corner lamp arear, it is a single bolt very easy to take off and put a new one in, the head light should be two top bolts and i believe one on the bottom, if you open the hood you can probably see the bolts and basic hand tools should be able to remove everything. hope this helps, those cars are asy to work on IMHO, I replaced the corner lights twice on my camry, take pics and i can show you exactly which bolts
Old September 21st, 2005, 05:13 PM   #4
4 bangin'
Sketch o5's Avatar
yea, it looked pretty easy. for the headlight, would i have to take off the fron bumper like on my accord? and any other place then ebay to buy from?........anyone selling theres? idk, ill look around as well.
Old September 21st, 2005, 10:17 PM   #5
4 bangin'
Sketch o5's Avatar
i found a place called yourautopartstore.com and they have the corners for like $40 and the headlights for like $97, that sound good?
Old September 22nd, 2005, 07:35 PM   #6
-Brian
NexsoN's Avatar
EBAY!, everything for cheap cheap cheap, and its oem oem oem
Old September 23rd, 2005, 02:09 PM   #7
Spyder's Avatar
car-parts.com
Spyder is offline   Reply With Quote Quick reply to this message
Old November 9th, 2005, 09:08 PM   #8
05AV6's Avatar
I never took out my headlight assembly, but im almost 100% sure u can get it off without taking off the bumper, honda only did that so that the lights were hard to steal, the corners hould take 5 mins max.
Old December 14th, 2005, 10:48 PM   #9
4 bangin'
Sketch o5's Avatar
anyone know if a 97-99 camry clear corner lense would fit on an 00? if not anyone know where i could get clear corners for a 00 camry? my mom now wants to get the red/clear tail light corners, and clear corners for the front. i found the red/clear tail lights, but i only found 97-99 clear corners. it looks like theyd fit tho, the mounting point looks the same.
Old December 15th, 2005, 07:55 PM   #10
4 bangin'
Sketch o5's Avatar
anyone?
