All this talk about 3.5L 268hp, but isn't the 3.3L more efficient/quicker? - Honda Accord Forum : V6 Performance Accord Forums
Old April 16th, 2006, 12:17 PM   #1
Hopefully Steve/Dizzy or other's technically inclined can answer:
1. If torque and/or hp are linear at any given point, then the lower the rpm they are achieved, the more powerful the model is. That being said, the 3.5L (2GRFE?) has 8 more lb-ft torque at 1100rpms higher and about 43 more hp at 800 rpms higher. Another side note, driving the Solara vs. a V6 Accord where peak hp/tq are at 5000+rpms, I get better fuel economy on the Solara b/c of better get up and go in the city.
Stats:
Camry Solara V6 (2005 Camry 3.3L not listed anymore)
5 speed auto sequential
3.3-liter DOHC
0-60mph in 6.6-7.2 sec
24-valve VVT-i V6
225 hp @ 5600 rpm
240 lb.-ft. @ 3600 rpm
(on premium, 8% hp/tq loss on regular)
curb weight 3417lbs-3439lbs
21/29mpg (on regular?)
-I get AVG of 28-29mpg combined of moderate driving on premium
Vs.
2007 Camry 3.5L V6
0-60mph in 6.5-6.8 sec
6 speed auto
3.5-liter DOHC 16-valve
Dual VVT-i V6
268 hp @ 6200 rpm
248 lb.-ft. @ 4700 rpm
curb weight 3461-3516lbs
22/31mpg (on regular?)
Fuggedaboutid is offline   Reply With Quote Quick reply to this message
Old April 16th, 2006, 01:36 PM   #2
Formerly VTEC-v6!
N54TT's Avatar
Before you start making judgements, consider that the 3.5L's ratings are in accordance with the new SAE spec, and the old 3.3's ratings (that you posted) are based on premium fuel.
Recheck your specs, then think about it some more
-James
Old April 16th, 2006, 04:14 PM   #3
VTEC V6, to be fair I mentioned 3.3L on premium = 225hp/240tq instead of 210hp/225tq?
Thing is the 3.5L doesn't mention in media reports any benefit on premium fuel in terms of numbers.
I should mention that I do have the 3.3L in my hands so I am a little biased even if I don't show it; however the 3.5L is better in terms of fuel economy. I know that the Lexus IS350 version recommends premium for the 306hp/250+tq.
Anyways, that being said, the 1-2mpg diff and no premium fuel = some cost savings, but the downside is trading in current car or replacing it = $5000-15000 difference in payments, so fuel economy alone isn't the biggest reason.
Old April 16th, 2006, 04:28 PM   #4
Accord_V6_400m's Avatar
Stats:
3.3-liter DOHC
24-valve VVT-i V6
225 hp @ 5600 rpm
Vs.
2007 Camry 3.5L V6
6 speed auto
Dual VVT-i V6
268 hp @ 6200 rpm
The old 3.3 does not compare to the new 3.5 at all. By far the new engine is much more advanced. Direct fuel injection allowing for better control and eficiency is just a part of it.
As for torque and horsepower it doesn't make a certain powertrain more powerful then another if its peak torque is sooner on the contrary for all you now the torque curve on the new engine could be much better overall and just continue for a longer duration of time, ie. its more flat and peaks later. They probably sacrificed peak torque for a flatter beefier torque curve basically. Plus on the new ratings the 3.3 got like 215hp I believe as compared to 268.
Old April 16th, 2006, 07:04 PM   #5
Actually, the new ratings SAE are 210hp for 3.3L on 87oct. Btw, the 3.3 does have "Ignition Electronic, with Toyota Direct Ignition (TDI)", but obviously not 268hp/6speed auto. I was just pointing out that Toyota is turning into Honda in terms of the 3.5L only b/c they have put more more hp than torque which Honda is known for.
Is it true that the Camry 3.5L is a detuned IS350 motor or is that urban myth... anyways, why do I get the feeling that my posts are really boring
Old April 16th, 2006, 11:41 PM   #6
Wow 210 theres a big difference. I wasn't refering to DIS (Direct Ignition System) but rather the Direct Fuel Injection as I mentioned in my earlier post. Don't worry Honda will catch up. You should try not to look at it in a more hp, less tq way, it will get you thinking a certain way, just look at the whole picture.
Its basically a detuned version minus some parts here and there. Its the same family of engines but its not "just" detuned.
Old April 20th, 2006, 06:43 PM   #7
Cool
No engine from the MZ, and the 2gr-fe are not happy on 87 octane fuels.
The MZ's have notorious timing retard, and pinging issues when running 87. The even higher 10.8:1 compression on the 2GR-fe is not going to lend itself well with 87 octane either. Tho the previous knock sensor issues have been fixed for quite some time.
Keep in mind... The 1mz/3mz topped out with the U151 transmission. The 2gr-fe get's the U161 transmission.
Old Gearing 3.29 * 0.76 * 215/55/17
New gearing 3.685 * 0.609 * 215/55/17
The extra mpg comes from both a more effecient engine, and the fact that the cruising gear is taller.
3000rpm, TC locked = 93mph VS 104 mph
ABout the power output. You're gravely mistaken. The 3mz-fe was *NEVER* quoted as having 268hp.
1) The 3mz-fe + hybrid drivetrain of the rx400h / highlander hybrid makes 268bhp combined
2) The 2GR-FE makes 268bhp. (Previously 272bhp)
1mz-fe w vvt-i (i.e. beams) 210bhp (now ????)
3mz-fe 218bhp. (Previously 225, before that 230 on the old bhp formulas at engine introduction.)
Which I think is a completely inaccurate statement. Even if similar in numbers, Toyota historically shoots for 95% peak torque no later 2500rpm on their "car" (not truck) v6's.
Which histrorically... Honda just doesn't *do* relative torque/horsepower in the first 1/3 of their entire rpm range on *any* of their engines.
So. No... It's not comparible. Nor similar in real-world regards.
Nissan w' Toyota? Ya, been comparible in many aspects for 15-20 years now. Honda w' Nissan / Toyota? No.
The entire GR family is much better than the MZ family. Stronger, bigger, more economical, and more power - in any relative measure.
Unfortuantly anything from either family runs 2,000-4,500usd in the parts chains right now.
Toysrme is offline   Reply With Quote Quick reply to this message
Old April 23rd, 2006, 10:57 PM   #8
When I said Toyota is taking the route of Honda with putting out more HP and torque not increased significantly, I was referring to the approach of number boosting. HP is all marketing to me, anything more than 200 is good, whereas torque, one can never have enough, let's just say .
Anyways, the 2GR is a great replacement for the 3mz/1mz, etc... however, I'm not completely sold on the gain of 8lb-ft of tq and raising of rpms . What that means is that the car isn't convincing enough for an existing owner of solidly functioning 1-5yr old 3mz powered vehicle, unless they have leased their car and need an absolute replacement. The MPG gain is however welcomed at any level esp with beautiful gas prices these days.
Btw, what's the biggest flaws or advantages to the 3MZ versus all Toyota or even competitior's engines?
Also, what's the biggest advantage to the 2GR (3.5L) Toyota motor compared to all other Toyota motors of past/present and those of other manufacturer's?
The reason for asking is that, many know that the Lexus/Toyota 3.0L I-6 in the IS300/Supra/etc was absolutely amazing in terms of build quality and handling of absolute abuse/thrashing. I have never owned one of these, but this is what I've heard.
Old April 24th, 2006, 12:38 AM   #9
Keep in mind that the power of their new engine improves torque everywhere in the powerband and has it continue for a longer duration of time which I wish I could say the same for diesels.
That and the 06 Camry with the 3.3L engine under the new ratings that the new engine is rated against only has 210hp @ 5600rpm and 220tq @3600rpm according to their pdf files:
http://www.toyota.com/html/tcuv/brochures/06_camry.pdf
So 58hp and 28lb-ft of peak power isn't a high enough increase not to include the bountiful amounts of technological innovations such as direct fuel injection.
The new engine makes [email protected] and [email protected] If Toyota indeed has the tradition of having torquey engines then one could assume that they increased torque and are producing it for a longer amount of time in the powerband.
Old April 24th, 2006, 07:50 PM   #10
I love this thread. I'm learning so much about Toyota's older V6 engines .
The 2gr-fe in the 2007 Camry, 2005-2006 Avalon and 2006 RAV4 doesn't have direct injection.
Old April 24th, 2006, 08:12 PM   #11
"Certified Hybrid Killer"
SteVTEC's Avatar
I should post up a thrust analysis, which would answer most of this in a about 2 seconds. hmm... which one. Has anybody dynoed at FWD automatic 2GR-FE car yet? I did one of a Camry 3.3 SE vs a 7g AV6 awhile ago but never posted it, because I figured it would just get people's pannies in a bunch and start a flame war. Had some pretty interesting results though.
The Toyota 3.3's are definitely tuned for good low-end torque, and have very aggressive gearing. So it may feel extremely responsive and quick around town, but that doesn't make it fast. Once you get wound up, 210-225 hp only accelerates you so quickly, and that's at a rate far slower than 268-280 hp will.
Old April 25th, 2006, 09:46 PM   #12
[QUOTE=SteVTEC]I should post up a thrust analysis, which would answer most of this in a about 2 seconds. hmm... which one. Has anybody dynoed at FWD automatic 2GR-FE car yet? I did one of a Camry 3.3 SE vs a 7g AV6 awhile ago but never posted it, because I figured it would just get people's pannies in a bunch and start a flame war. /{QUOTE]
We are mature adults LOL... anyways, people like me who have both in my household would love to see those results SteVTEC. Please post the 3.3L vs Av6 Gen 7
Steve, maybe we all including myself as underestimating the potential of HP b/c we are awashed with marketers saying "300hp this and 200hp that" while haing 195lb-ft torque or something lousier.
btw, SAE 210hp/220lbft on regular for 3.3L .. I do use premium, not for power reasons, but for better fuel economy and smoother driving which has helped me a lot to gain 4mpg b/c of more linear/less lag.
Old April 25th, 2006, 09:59 PM   #13
SteVTEC's Avatar
And on that front, my 190 hp Maxima is just as quick as a 300 hp RL.
Old April 25th, 2006, 10:59 PM   #14
hi Steve, can you post the 3.3L vs. Accord 7th gen V6?
Old April 25th, 2006, 11:13 PM   #15
SteVTEC's Avatar
yeah i'll get around to it. gimme a few days
Old April 26th, 2006, 11:05 AM   #16
Steve didn't you post one up before on a Solara 3.3 vs. an Accord J30A4?
I recall last year that alot of people were in a rut because alot of people weren't understanding the concept of 3D acceleration and assumed that the Accord was ahead by 70mph because it posted a quicker time-to-speed.
Max on This is offline   Reply With Quote Quick reply to this message
Old April 26th, 2006, 11:46 AM   #17
constantly in pursuit
hammer03's Avatar
have you calculated the $/mi instead of mpg to see which is more cost effective?
Old April 26th, 2006, 11:52 AM   #18
SteVTEC's Avatar
I'm not sure what I posted and got flamed for before.
Anyways, in one file I have an extrapolated dyno/thrust analysis for an Avalon (2GR) raping a TL which got the Acura guys' pannies in a bunch a year ago. And then in another file I have a 3MZ doing the deed on a J30A4, at least at lower speeds. I'll just splice together a new one and put the 2GR 6AT up against the old 3MZ 5AT, which is what the thread is about anyways. I'll get to it this weekend sometime since my wife is on call most of the weekend.
Old April 27th, 2006, 06:52 PM   #19
Cool
Btw, what's the biggest flaws or advantages to the 3MZ versus all Toyota or even competitior's engines? Also, what's the biggest advantage to the 2GR (3.5L) Toyota motor compared to all other Toyota motors of past/present and those of other manufacturer's? The reason for asking is that, many know that the Lexus/Toyota 3.0L I-6 in the IS300/Supra/etc was absolutely amazing in terms of build quality and handling of absolute abuse/thrashing. I have never owned one of these, but this is what I've heard.
The 3mz-fe is better than a 1mz-fe. Compaired to other similar configuration engines it depends on what the criteria is.
The 2gr-fe is a great engine. Gobs of torque, good horsepower output, very broad power output. One of it's major strengths will be it's lineage. It will prove equal to the older Toyota v6's in it's power holding ability. 400-550bhp should be where it falls ones people start playing with it.
You're reffering to the 2jz-ge. They are very strong. The differances between a 2jz-ge, and 2jz-gte are well published, and very minor. Realize that previous v6's, stock/stock, and paying careful attention to fueling to not melt a piston, or ring-land, are nearly as strong as "legondary i6's."
With most of the v6's Tapping out for day to day reliability under boost/n2o at 375-550bhp.
That's not shabby...
SteVTEC Dynos are not known to exists outside of the FSM's at this point. If you have one... Post up.
Old April 28th, 2006, 01:42 PM   #20
hammer03's Avatar
ummm excuse me? are you sure about that?
Old April 28th, 2006, 04:58 PM   #21
streetxdreamer's Avatar
sorry to jack the thread but i was always under the impression that premium fuel in a car does not do jack for a car that does not require it. Fuel grade is based on its octane rating, As you should not the octance rating is the fuels ability to not 'auto-detonate'. That is the only thing it does, it does not make more power and it does not get you better mileage.
Please correct me if im wrong
streetxdreamer is offline   Reply With Quote Quick reply to this message
Old April 28th, 2006, 06:26 PM   #22
The 'new' way does make for more power with premium as the ratings are made with regular fuel (GR Camry motor)
In a nut shell: The ECU will slowly advance timing until pinging is determined. The timing is more advanced with premium than regular. This in turn makes for more power so HP and TQ will go up. This won't happen right away, the ECU takes time to advance timing, it mainly does it at steady state cruising.
The 'old' way was to rate the car with premium fuel (1MZ). Regular fuel will cause knocking, so the timing will be retarded. This will make you loose power (lower than the rated HP/TQ).
Cars such as the Accord with the J30A1 is rated at regular, but provides no benefits with premium. There is no knock sensor to determine engine knock so it makes due with very conservative timing that doesn't change regardless of octane.
Old May 22nd, 2006, 10:02 PM   #23
Cool
Piston oil squireters & static compression ratios are the only noteable differance between a 2jz-ge and a 2jz-gte.
Excuse yourself for not knowing...
Go spend some time learning Toyota doesn't build **** that falls apart - even tho they don't build anything that leads in power production.
Old May 22nd, 2006, 11:12 PM   #24
hammer03's Avatar
so why is it that they dont hold boost even remotely as well as the gte?
and you dont have to be a **** about it.
Old May 23rd, 2006, 02:14 AM   #25
Cool
The largest starting reason is the effective compression ratio under boost. One runs a 10:1 to 10.5:1 CR, the other runs 8.5:1 CR. Right off the bat the GE is penalized at 1 bar of boost by having a 3.8:1 higher peak effective compression ratio.
Which runs back to the delima alot of people with 2jz-ge powered cars get into:
1) Rebuild the 2jz-ge into a stronger than stock 2jz-gte for the same cost
2) Buy a 1jz-gte, possibly rebuild it
3) Buy a 1uz-fe, rebuild it, turbo that
From the MKIV.com FAQ
The NA engine is internally built just as strong as the TT engine, and responds Well to turbocharging. You can increase horsepower levels with a turbo kit To around 600hp reliably. Click Here to see how far an NA has been taken to, 700hp+! And click Here & Here to read about it
I'm not being a ****. If I were being a ****, I would insult someone. I'm just clearing afew things up.
Old May 23rd, 2006, 05:04 PM   #26
Guys, c'mon are you trying to get banned!!! lol, an innocent engine question and my V6P people are cursing or cussing? out each other! It's a Toyota engine lol, let's not fight!
Old May 23rd, 2006, 05:44 PM   #27
Formerly VTEC-v6!
N54TT's Avatar
How about I just ban all of you? Huh? Yeah sounds good
Old August 19th, 2006, 10:15 PM   #28
Gas Mileage and octane rating
I recently ran a test on my '05 3.3L V-6 Camry and it got 2 mpg better on 87 octane than on 91 octane.
Bill
[QUOTE=Fuggedaboutid]
k5wg is offline   Reply With Quote Quick reply to this message
Old August 19th, 2006, 10:29 PM   #29
gas mileage and octane rating
I just ran a test on my '05 Camry 3.3L V-6 and got 2 mpg better on 87 octane than I got on 91 octane.
Bill
Old August 20th, 2006, 12:34 AM   #30
Formerly VTEC-v6!
N54TT's Avatar
Under what conditions did you perform the test? I'm a Toyota guy too so I'm not flaming...but I just want to make sure there weren't any extraneous variables that you missed that would have thrown the results
Garage:
  • 2017 Chevy Tahoe LT
  • 2016 BMW 535i M-Sport
Gone but not forgotten:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
