Lowering Tutorial - Honda Accord Forum : V6 Performance Accord Forums
Old April 29th, 2003, 07:22 PM   #1
Formerly VTEC-v6!
N54TT's Avatar
Lowering Tutorial
Heres a simple, but fairly detailed tutorial on how to lower a car, from an angled view in photoshop (pics included)
Heres our original image, a 2004 Acura TSX Background
What I plan to do, is to lower the car about 1.7 inches in the front, and about 1.5 in the rear to give it a more agressive stance.
First things first,
In order to be able to lower a car in photoshop, you must have a basic understanding of some of the more basic tools.
Tool # 1. The Polygonal Lasso Tool (Shortcut Key: V)
It is used for selection areas with variable precision. How accurate and jagged your selection will come out, depends on how far you zoom in, and how many times you click the mouse. The further you zoom in, the more accurate it will be, and more clicks, the less jagged the selection will be. To use the polygonal lasso, select the lasso button from the toolbar on the left
and click a single point on the image to start the selection, as you click, the line will have a pivot point, and you can point the selection line in a new direction.
When I lower cars in photoshop, I always use the polygonal lasso, and I generally start on the left hand side of the image. The first point i click is on the very far side of the image, usually off the image sometimes as to make sure the entire side area will become selected in the end. I try to make my first point in an area where displacing part of the image will not make a huge effect, hence the reason why my selection does not start on the ground with the gradient shadow, I chose to select the left side where the background of the image is nearly a flat grey color. Then just click along the outline of the body parts making sure to keep abotu 1 pixel outside the car at all times to make sure you get the whole body selected. Once you have made it to the other side of the car, go off the other side of the image, and come up and around to select the rest of the image above the vehicle. Here is my final poly lasso selection:
Notice how I did NOT select the wheel gap, since we intend to get rid of it anyway.
Now for step two: Moving part of the image
Tool # 2. The Move Tool (Shortcut Key V)
Select the move tool by either clicking the above icon on the toolbar, or by pressing the shortcut key V.
You can then click and drag your selection whereever you wish on the image, for this slight drop, only a slight movement is needed.
Here is the image after the move:
Now notice the black area on top of the image, we will get rid of that later so dont get all freaked out yet.
Step Three: Dropping the Front Lower Than the Rear
Tool # 3. The Free Transform Tool (Shortcut Key Ctrl-T)
For most slight drop differences, the free transform tool will help you greatly, it allows you to resize the selection, rotate it, skew it, modify it for perspective points etc....
But for now, press CTRL-T after you have selected the area to open the free transform tool. A rectangular line with 8 Boxes on it (1 per side, 1 per corner) will appear around your selection.
If you click and drag the boxes, your selection will be distorted in size and shape, but since we dont want to do that, we want to drop the the front of the car instead, what we will do, is move the cursor outside the box, and it becomes a rotational tool. So just click and drag outside the box, and the selection will rotate, since we only want a slight difference in the drop (0.2"), we will not rotate it very much. When you have acheived the desired angle, release the mouse button, and press ENTER, this will save the transformation changes you have made, to the image history, and exit the free transform tool.
Step Four: Getting Rid of The Black Space
First thing, deselect your selection (CTRL-D)
Tool # 4. The Rectangular Selction Tool (Shortcut Key M)
Select the rectangular selection tool by either clicking the above icon or by pressing the shortcut key M.
What you will want to do, is select all of the image that is visible, EXCEPT for the black area, which you do not want to have!
OPTION 1.
Then we will crop the image to get rid of the black area
Tool # 5. The Crop Tool
The Image Cropping Tool Can be found on the Image menu, and it is called CROP
Once you click CROP, only the selection will remain in the image, and all that ugly black area will be gone.
TADA!!!
OPTION 2. (Works or does not work depending on the image background)
Use the rectanguar select tool to select some of the non black grey area at the top of the screen, press CTRL-T to open the free transform tool, and drag the boxes on the rectangle to adjust the selected grey area to cover up the black space. When done, press ENTER.
NOTE: Apply the same technique to getting rid of the black area on the sides also. This method does NOT ALWAYS WORK for getting rid of the black area, especially when it comes to having natural backgrounds such at trees.
Here is the final image of our lowered TSX:
Hope this helps, good luck and have fun.
Any comments or suggestions will be noted, and I may edit this tutorial to include them!
Garage:
  • 2017 Chevy Tahoe LT
  • 2016 BMW 535i M-Sport
Gone but not forgotten:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
Old April 29th, 2003, 07:35 PM   #2
nice tutorial
morpheus6d9 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2003, 07:37 PM   #3
Formerly VTEC-v6!
N54TT's Avatar
thanks
Garage:
Old April 29th, 2003, 08:41 PM   #4
nice tutorial!! one thing you might want to edit in your how to. i noticed you got rid of the black along the top. in addition you might want to get rid of the black on the left and right sides in the same step. i believe the black spots on the sides appeared because you lowered the front more than the back
davejax904 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2003, 09:38 PM   #5
Night Kid #999
AccordTypeR's Avatar
Send a message via AIM to AccordTypeR Send a message via MSN to AccordTypeR
CoOl TuToRiAl~~
AccordTypeR is offline   Reply With Quote Quick reply to this message
Old April 30th, 2003, 08:24 AM   #6
Formerly VTEC-v6!
N54TT's Avatar
i figured the user would be able to use the same technique to get rid of the other black area, the only method where i did not mention getting rid of the black on the sides is the method where you resize the bg, thx for the suggestion, ill change it
Garage:
Old April 30th, 2003, 11:41 AM   #7
NICE tutorial!
ZxNiTrOxZ is offline   Reply With Quote Quick reply to this message
Old May 5th, 2003, 09:25 PM   #8
___
borinka99's Avatar
Wow, awesome tutorial, made everything really easy!
Any tips on rims/bodykits for a newbie?
borinka99 is offline   Reply With Quote Quick reply to this message
Old May 5th, 2003, 09:27 PM   #9
Senior Moderhater
abram2001's Avatar
nice VTEC-V6 this is very informative, if anyone needs more help just go to www.photoshopjunkie.com
Old May 5th, 2003, 09:36 PM   #10
Send a message via AIM to SlvrBulletV6
Wonderful! Million eProps for you. (
SlvrBulletV6 is offline   Reply With Quote Quick reply to this message
Old May 6th, 2003, 03:18 PM   #11
Formerly VTEC-v6!
N54TT's Avatar
all in time, all in time, ive been busy lately
Garage:
Old May 6th, 2003, 03:58 PM   #12
___
borinka99's Avatar
no worries, take your time
-Boris | Senior Moderator | So Cali Chapter Mod | Random Chatter Mod |
You can never master the game until you realize that it can never be mastered!
How to post pics:
Old June 5th, 2003, 03:02 PM   #13
(^_^)
(^_^)'s Avatar
here is a crude instructional image i made for Frank828. It helped him. Bleh.
(^_^) is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 03:10 PM   #14
Great tutorial
This should help me out with future calendars .
Old June 13th, 2003, 04:50 AM   #15
MAN... this is why I love this FORUM SO MUCH!!! THANKS!
EnvyJK is offline   Reply With Quote Quick reply to this message
Old June 13th, 2003, 11:30 AM   #16
One Suggestion for those who know how is to use the Pen tool. I've done complete re-colorings for people using this method. You can get better curves in the wheel wells and anywhere else you need. But awesome tutorial.
slimtwigmj is offline   Reply With Quote Quick reply to this message
Old June 13th, 2003, 12:06 PM   #17
Formerly VTEC-v6!
N54TT's Avatar
damn str8 fool
Garage:
Old June 13th, 2003, 12:08 PM   #18
eProps man, Everyone give it up for VTEC-V6.
Old June 17th, 2003, 04:36 AM   #19
Thank you for that tutorial, i went through it and now i cant stop lowering everycar i have pics of. I tried to do street bikes as well but htey are hard to do. If you go any more tutorials post them up!
phool2 is offline   Reply With Quote Quick reply to this message
