navigation image - Honda Accord Forum : V6 Performance Accord Forums
Old May 4th, 2003, 02:28 AM   #1
navigation image
How was the image in the top navigation bar created? How do you create the vertical lines and the blending with the shifter and the two cars? Any filters for the verticles lines and blending? How's you blend the tachometer?
01coupe is offline   Reply With Quote Quick reply to this message
Old May 4th, 2003, 02:40 AM   #2
I will see if I can explain this. You can put the two images, one on top of the other like in the navigation bar. Then use the large circular eraser and delete the edge of the sifter picture (must be a separate layer form the car pic) and you get that blending effect. This is one way to do it and I think the easiest. To get the right effect takes trial and error but it isnít that hard to make it look like the navigation bar.
Hope this helps. Plum's out .
