03 Accord V6 power steering return, hard line.
439 Views 5 Replies 2 Participants Last post by  Soopadoopa
hey wrench turners! happy cinco de mayo from San Diego!
The Power steering (low pressure return line) hard line was not fastened properly and as a result it was rubbing the axle. It wore a hole in it. :confused:
What is the easiest way to swap that hard line out? 😅
its a pretty long line and goes above the steering and under the axle, connecting towards the front passenger headlight area...
Got one from the junk yard and ready to put her in this weekend.
The part im talking about is part #
Honda (53779-SDB-A00)
(#13 on this diagram)
Your responses are greatly appreciated.
Gesture Font Auto part Circle Art
See less See more
1 - 6 of 6 Posts
All good. Got it in. (y) 🔧
1. took off the bumper.
2. fed the hardline in from the front.
3. used a angled tip of a prybar to guide "shoehorn" the front barbed end of the hardline, working it around the axle and subframe stopper.
note* I had to give it some tough love, flexing it a slightly to get it where it needed to be.
connected the rubber hoses, topped off fluid. so far so good. 😅
Mission accomplished. just in time to watch the Padres beat up the Dodgers. 😝🍻
  • Like
Reactions: 1
Nice work. Feel free to share any pics or tips you may have picked up along the way.
3
Automotive tire Motor vehicle Automotive exterior Rim Automotive wheel system
Automotive fuel system Motor vehicle Automotive tire Automotive design Hood
Mounting bracket was not bolted dn.
Automotive tire Automotive fuel system Motor vehicle Automotive exhaust Automotive exterior
See less See more
2
Automotive tire Tire Bicycle part Motor vehicle Bumper
I had to drop the front bumper and remove the oil filter in order to feed the hard line through the front. It has to go on the inside of the subframe bolt. I didn't think I'd be able to make it happen but thankfully, with the help of a small pry bar (harbor freight), it did. 🍻
Automotive tire Light Camera lens Grey Gas
See less See more
View attachment 22097 I had to drop the front bumper and remove the oil filter in order to feed the hard line through the front. It has to go on the inside of the subframe bolt. I didn't think I'd be able to make it happen but thankfully, with the help of a small pry bar (harbor freight), it did. 🍻
Kudos, sir. And I thank you for your efforts to take pics, post them, and share.
1 - 6 of 6 Posts
