1 - 4 of 4 Posts
18x8
I am interested in these Montegi Rims,
18X8 with a 40mm off set will they fit my 03 ACCord Coupe Lowered on HR sports. Will they fit? Will they rub?
I can't answer your question specifically, but from first hand experience know that 19x8 45mm offset doesn’t rub without modification.
are you running a camber kit? so teh 18X8 with a 40 mm off set shuold be fine, I need a rear camber kit if I get rims or else I will chew through tires, and input, thanks for the help man
1 - 4 of 4 Posts
