1 - 9 of 9 Posts
Hello to all. I'm new to the tuner scene and have some questions about tire size for the rear. I am wanting to purchase the vvs086 wheel from vossen. I have the h&r springs and would like to know if any one is running this set up with the vossen wheel using the 285/30/20. If so did you have to roll the fenders in any way or is there enough clerence with that size tire. I just don't want to run into any problems.
Thanks
James
285 ... 20s on springs is alot to do... your gonna need alot of work. honestly idk if thats gonna fit. i dont have an 8th gen, i have a 7th, but that seems huge
lol wut
you will need a good amount of camber in the rear as well as a nice fender roll and pull in the rear to accomodate a 285 tire on a 20in rim. In short, you will rub unless you do some major fitment work. Riding on springs alone won't cut it, you need a camber kit as well.
Brad
What wheel specs are you planning on running a 285/30/20 on? I'd love to see how that looks properly fitted on an 8th gen Accord.
Thanks
I just installed 285/30/20 rear and 255/35/20 front on 20x10 wheels on stock suspension
1 - 9 of 9 Posts
