1 - 6 of 6 Posts
Hi, I have a 1995 buick lesabre with 3800 (rod knocking).I also have 1988 olds ciera with buick 3.8 buick (bad fuel pump).I would like to know if basic short blocks are same. I would like to replace 3800 with the 3.8 and use 3800 exterior engine parts on 3.8.Is this possible?Please help: Earnhardt fan
Formerly VTEC-v6!
Thread moved :)
Welcome to V6P, and good luck with the swap...sorry I don't have the answer you're looking for though :wave:
"Certified Hybrid Killer"
there aren't any 3800 tech heads here that I know of, but definitely give www.clubgp.com a try.
Is that cierra front drive? I thought the 3.8 was in rear drive platforms, like the V6 camaros and firebirds, and the 3300 and 3800 (these 2 are interchangable) were for front drive platforms, cause my '90 cierra was front drive with a 3300. I've heard that the 3.8 and 3xxx series are very different, not even sharing the same block angle (3.8 is 60, 3xxx is 90).
1 - 6 of 6 Posts
