1 - 18 of 18 Posts
Crimson Tide
SOLD to Nicepeta for $350.00 shipped. You see guys! I'm not so tough to negotiate with!!!
Selling these tires since I sent my rims back to DTD for a full refund. Going to a negative offset 17" setup next month and wont need 18" tires anymore. These tires are awesome and will stick like glue whether it's wet or dry. If you like driving your car hard, going to the track often, or simply like to drive spirited, these tires are for you. Pics and specs below:
Azenis RT-615
Street Legal Motorsports and DOT Approved Track Competition Tire
Today’s sports cars, compacts and performance sedans are extremely versatile. The tire they ride on has to be the same. The new AZENIS RT-615 offers a world spec construction, featuring an improved motorsports-grade cap compound that effectively maintains grip as tire temperatures increase. In addition, the special 8/32nd molded tread design reduces the new tire’s tread squirm while providing efficient mileage for street use. A solid center rib significantly reduces wheel spin by increasing the tire’s contact patch void ratio under heavy acceleration. Understanding the tremendous demands the AZENIS RT-615 will experience, new proprietary casing design, bead apex and turn-up technology allow for the elimination of heavy steel construction, resulting in an 8% reduction in unsprung tire weight.
In its category, the Azenis RT-615 performs well in wet conditions. 8/32 tread depth and optimized aqua tusk positioning, allows better tread adhesion as it delivers ample wet grip performance. Matched with three high void low turbulence grooves, consistent, and in some cases, increased, wet weather speeds can be achieved as potential hydroplaning tendencies are reduced.
The result: A tough, durable, street-sensible tire, whose 200/A/A UTQG rating, make it a great match for the autocross, time attack, or drift competition.
* MASSIVE SPORT SIDE SHOULDER BLOCKS deliver motorsports level grip and unsurpassed durability
* THREE HIGH VOID/LOW TURBULENCE GROOVES increase maximum wet weather speeds and by reducing hydroplaning tendencies
* SOLID CENTER RIB significantly reduces wheel spin by reducing contact patch void ratio under heavy acceleration
* OPTIMIZED AQUA TUSK POSITIONING reduces tread squirm while delivering flagship wet grip
Asking $450.00 Shipped OBO. Need these gone before New Years!
Dayumm, give me about 2-3 weeks! I need tires ferr sure and this is a killer deal. Just need to gather up some dough!
1 - 18 of 18 Posts
