1 - 18 of 18 Posts
headlight for all 7th gens(2003-2007) sedans, coupes, any trim.
condition: 7/10 because one 1 blemish, but the rest is good. comes WITH both low and high beam bulb.
$30 picked up in socal.
blemish:
Hey man, thanks for the PM... Does this headlight have an indentation in the low beam area of the lense? I believe it was a thing from the factory
Kind of like a slight flat spot in the middle
umm im not sure what you are referring to, can you show me on a pic where its located?
I don't have a pic right now, but it is basically in the middle of the low beam portion of the lense. You have to look for it. It is about 3.5 inches in diameter I would approximate. Round, and when looking at the lense from the side kind of, it almost looks resemblant of a magnifying glass sort of.
I think LFSoccer should have a pic somewhere
Discussion Starter #16
im not sure this can be "fixed" because you can feel it if you rub your fingernail over it.
if i had to take a guess, it would be the clearcoat that has cracked
1 - 18 of 18 Posts
