1 - 14 of 14 Posts
14.58 =Quickest Gen7 auto
7th GEN. WHEEL SPECS & INFO
Note: All rims are 5 lug x 114.3 mm (4.50") bhc (bolt hole circle).
15" DX/LX-I4 Steel Rim
Description - Black Painted Steel with Silver Plastic Wheel Cover
Size - 15 x 6.5
Offset - ?? mm
Weight - ?? lbs.
Weight w/tire - 39 lbs. (205/65-15)
16" LX-V6 Steel Rim
Size - 16 x 6.5
Offset - ?? mm
Weight - ?? lbs.
Weight w/tire - ?? lbs.
16" EX-I4 Alloy Rim
Description - 5 Spokes, Machined Finish
Size - 16 x 6.5
Offset - 55 mm
Weight - ?? lbs.
Weight w/tire - 39.5 lbs. (205/60-16)
16" EX-V6 Alloy Rim
Description - 7 Spokes, Silver Painted Finish
Size - 16 x 6.5
Offset - 55 mm
Weight - 19-20 lbs.
Weight w/tire - 41-42 lbs. (205/60-16)
17" 6MT Alloy Rim
Description - 7 Split Spokes, Silver Painted Finish
Size - 17 x 7
Offset - 50 mm <---***Needs Confirmation***
Weight - 23-24 lbs.
Weight w/tire - 45-46 (-48??) lbs. (215/50-17)
17" HFP Alloy Rim
Description - 5 Spokes, Gunmetal Painted Finish
Size - 17 x 7
Offset - 55 mm
Weight - 22 lbs.
Weight w/tire - 43 lbs. (215/50-17)
(Note: This rim is also the optional TSX SilverStar rim.)
17" TSX Alloy Rim
Description - 7 Spokes, Gunmetal Painted Finish
Size - 17 x 7
Offset - 55 mm
Weight - 21 lbs.
Weight w/tire - 48-49 lbs. (215/50-17)
To the best of my knowledge, this information is correct. I didn't actually do any weighing myself....... I gleaned this data from many posts here, and elsewhere. Keep in mind, some people's scales could be off a pound or two, so use these weights with a grain of salt. ;)
Also, some of the data doesn't quite jive. Case in point, the 17" TSX 7-spokers are listed as weighing 21 lbs, and the 17" HFP's as weighing 22 lbs...... only 1 pound difference, yet the tire & wheel combo weighed 5-6 pounds more...... doesn't make sense since they should have the same (or nearly the same) weight tires on them. So :gotme: . In this case, I tend to believe the HFP numbers are correct (courtesy of Mackdaddy), and the TSX rim weight is low.
Someone also said the 6MT rims have 50 mm offset. Seems odd since all the other rims have 55 mm offset. If somebody could check that, it'd be great. I think the offset number is cast into the back of the rim.
If anyone can supply any "missing" data, post it up and I'll update the info. Or, if you believe anything is wrong, please let me know. I also add data as I come across different posts with useful info.
_
I want to find out the weight of the LX V6 16's with the hubcaps....I'm just curious how much weight can be knocked off with different wheels.
Discussion Starter #3 (Edited)
Sorry. Missed those rims. :smack:
Now you've got me wondering if the steelies I listed are the 15", or if I somehow mixed them up with the 16" steelies. I'll dig and find out which it is. :)
Edit - The info I had was for the 15" steelies...... I still need the info for the 16" steelies (on LX-V6).
sophmeat said:
Anyone have wheel weights for Acura TL OEM wheels?
ditto!!! esp. TL-ASPEC 18"s in gunmetal, so hot!!! :D
I read from the other forums I forgot if it was accordtuner, driveaccord, 7thgenaccord, or hondasociety that the TSX wheels are 23-24 lbs
the tooth
my little contribution that i measured this past weekend:
OEM 15 x 6.5 LX Steelies with oem tire: 41 lbs.
18 x 7.5 Rota Subzero with 225 40 18 tire: 41 lbs.
17 x 7 2001 OEM Acura CL-S with 215 50 17 tire: 50 lbs.
Banned
16" EX-I4 Alloy Rim
Size - 16 x 6.5
Offset - 55 mm
Weight - ?? lbs.
sorry to bump this up, but i put the EX I4 rims on my dad's 2004 Accord EX-V6 coupe, and they fit fine, but the brake calipers barely cleared them. The car drives fine, but is there going to be a problem, or am i fine with the rims ?
EliteCM.net
17" 6MT Alloy Rim
Size - 17 x 7
Weight - 23-24 lbs.
arent they 5 split spoke?
06-07 rim weight 43-45 lbs. I have hankook v12 on them. And yes bump from the dead
Javy
Agressive stance
I have an 07 accord and i want an agressive stance with the wheels i pick. Rolling fenders, will 18x9.5 +12 offset all around fit good? Maybe some camber done too? Thoughts?
1 - 14 of 14 Posts
