1quick240
I have a 95 S14 that I am thinking of selling. I am looking to get about 13.5k for the car, the car has lots of mods and recently I put in a new red top with new bearings, seals, gaskets, water pump and ect. Here goes a list of the mods and pics of the car too:
S13 Redtop
S14 Transmission
3-puck Clutch
Knock off Greddy intake
Nismo 740cc injectors
Greddy Rocker Arm Stoppers
Garret T3 60-1 .70A/R Turbo
Full Race Exhaust Manifold
Tial 44 mm V-band Wastegate
Bosch Wideband Sensor
AEM EMS
AEM A/F Gauge with o2 sensor
AEM Boost Gauge
Autometer Dual Guage Pod
Momo Steering Wheel with quick release
Fueled Front Mount kit
Koyo R Radiator
Dual 12" Electric Fan setup
R33 Differential (5 bolt axles -- thicker than S14)
Enkei RPF1's 19x8.5 (235-35-19) and 19x10 (255/35/19) 22+ offset all around
Tanabe Sustec Pro Coilovers S-OC Type IIs
Tial 50mm BOV
Greddy Catch Can
Apexi N1 exhaust
Catco Catalytic Converter
Optima Battery
Greddy Turbo Timer
Optima batter relocated
Panasonic Stereo
Orions 6.5 speakers- 4 of them
Whiteline sway bars
Dupree subframe spacers
Energy suspension bushings throughout
Nismo Oil Cap
Nismo Radiator Cap
Sparco Shift Knob
Limo Tint all around
The are a couple of bad things with the car...
1. It has a fully functional AC system, but you will need better fans because car over heats after like 15 min. of driving.
Either than that, I cant think of anything else...Oh and has a Clean title and its drift ready
Also, car has about 151000 miles and you will also have an extra redtop motor. It only has spuned bearings in it, you can build it on the side. Also, price isnt firm willing to negotiate, I can sale the car cheaper but will have different rims.
1quick240
Discussion Starter #2
here go some old numbers with the old sr
the new numbers that i got are identical to these, just at low boost instead of hitting 16 psi, i achieve those numbers at 14 psi and at 24 psi the car hit 456whp if i remember correctly. Also this motor seems to be stronger then the other just because it got the same numbers considering this time around they were done at 107 degrees vs. 70 degrees
1quick240
bump....opent to trades as well...whether it be a car or bike plus cash
