Discussion Starter · #1 ·
Whenever I hit the slightest bump in the road my ABS & Emergency Brake light come on. They stay on for a bit then both turn off... now when the ABS is on I tested it and it does not work. Any ideas?
I would bring it to the dealer there is nothing that you can really do. They will look up the ABS on the HDS and look for any DTC's stored in the ECM, if not they will have to diagnose it and do some troubleshooting, there are several procedures that will then have be done to diagnose the problem.
Discussion Starter · #3 ·
I fixed it it ended up being a ground I loosened when I was installing my HIDs so I just had to tighten one bolt. But my CEL was still on so I took it to the dealership I ended up havign a broken 02 piece.
