Discussion Starter · #1 ·
Hey guys, I have a 2007 saturn vue with a 3.5 j35a3 and I need help with wiring up the sensors. Everything is honda even the computer and I do have the wire diagrams for the car I just need to know are the cam and crank sensors Hall effect or Mag on the j series engines, what crank sensor did you hook to sensor A or B and if you connected you injector wires from the ecu ie. Injector 1,2,3,4,5,6. Or did you use the ground side?
Any help would be appreciated thanks in advance!
Rectangle Schematic Font Parallel Map
J35 _ 5-Speed A/T
HALL Effect for the J30A4/A5.
There are some threads on wiring up the FIC-6 in the 7th gen section, you are going to have to dig through them. You may need to try another J series website for your other questions because this website is pretty much dead..all the experts have been long gone.
Mr. Detail
Try poking around on acurazine, that's still a pretty active site.
