1 - 8 of 8 Posts
Audiobahn A2801Q Amp - $150 obo
200x2 @ 4ohm
280x2 @ 2ohm
560x1 @ 4ohm
This amp has couple of issues. First, when it is mounted vertically (such as behind backseat), the fan noise is VERY annoying. It seems to be fine when mounted on a flat surface though. Secondly, my system has been having problems. This amp powers up, but the subwoofer that is was connected to didn't bump. I can't tell if this is a problem with the amp, or somewhere else in the system. Im pretty sure its a problem somewhere else in the system, so this amp should work. If someone buys this, and isn't satisfied, I'll gladly take it back.
10" Subwoofer box - $30 obo
Seems to be a 1.00 cubic ft. Nicely built, no leaks.
2K1 SyLvRyD
id love to get the amp, but if its not gonna work they why buy it, you know you could take it to best buy or an install place and they could check it for you, my amp just went out... its powers up fine, but doesnt put out anything, just like you said your amp does. so the amp could be dead. if you could check it out, and show that it works, ill take it. let me know
1 - 8 of 8 Posts
